I just rounded out a bolt that holds the mudguard on at the bottom, between the chainstays at the small bridging piece that spans them. Cart of a place to do it, little room for maneuver. Any ideas on how to get it out?
Posted : 10/04/2010 7:48 pm
Can you hacksaw a slot across it, and use a flat head driver?
Posted : 10/04/2010 7:53 pm
I probably could mate - will a hacksaw cut into the bolt head? I'll give it a go and see. Thanks.
Posted : 10/04/2010 7:59 pm
Should cut it ok. Prob be best with a junior. Is it rusty? Might be worth spraying it with something like RostOff or similar.
Posted : 10/04/2010 8:02 pm
use two hacksaw blades side by side to get a wider slot if you can.
Posted : 10/04/2010 11:08 pm
