If it’s a standard size and the frame is still square it’s a doddle. Easier to hang doors if you’ve got a second body. Pop some cardboard or 3mm ply or something underneath when you do it to make sure it’s not dragging on the ground.
There’s also some guides you buy to make sure hinges are spot on, frame/door line up, they are great but expensive, although if you are doing all of the doors maybe worth it
If it’s a weird size it’s still easyish to do but involves a custom made door. If the frame is squint it’s going to be a right pain in the bottom. I made a door for my bike shed, the door aperture is nowhere near square, actually found it really satisfying to do, took a couple of days.
