Home Forums Chat Forum Pulse oximeters- so much choice!
Viewing 16 posts - 1 through 16 (of 16 total)
  • Pulse oximeters- so much choice!
  • Ambrose
    I’m a biology teacher. I am thinking about buying a set of pulse oximeters for use in class. Has anyone got any recommendations for a suitable model? Value for money, reliable, well constructed- with these things is it a case of pick any two?
    grahamt1980
    Look for CE and or UKCA marked ones.
    Probably better to buy from a medical device supplier rather than amazon,  but if you don’t need them to be that accurate or medical device grade then get cheap ones on amazon
    2
    I went cheap from eBay it was as effective as the machines at work which are 1000s more.
    Ambrose
    @Drac, do you think that the £5.00 jobbies would OK for a class of teenage pupils?
    Absolutely. If it’s to just show them SPo2 levels then more than good enough. You’re not using it as a diagnostic too so don’t need to be accurate.
    luke
    No point in spending large amounts of money on them.
    My last one was under £15 and colleagues have paid sub £10 they do the job there designed for.
    Ambrose
    Brilliant, many thanks for the advice.
    Background to this is that we were given two devices years ago as a part of the London 2012 legacy. The pupils have always loved using them. I always thought that they’d be quite pricey and was pleasantly surprised at the cost when I looked.
    So, based upon the advice received from some random people on the internet I think that due diligence has been done and I can order fifteen with a clear conscience 😂🤫
    Fun fact, quite a few pupils think that they have a different pulse rate in different places in/on their bodies.
    3
    TiRed
    Buy cheap. They are medical devices and certified. I tested my cheap one at the GP when I had a check in for my Long Covid. Was fine.
    they dont have to be accurate for you, only consistent.
    thelawman
    and
    These two statements don’t quite add up 😆
    ratherbeintobago
    Useless fact – pulse oximetry was calibrated by making medical students hypoxic, so anything less than about 80 is extrapolation.
    grahamt1980
    Plus if you happen to have a darker skin tone,  they don’t work as well.
    Unless someone has managed to update them since they discovered that issue
    Ambrose
    @thelawman
    I always like to know where my pupils are starting from.
    IdleJon
    The pulses in your feet need to work twice as hard to get blood back to heart than the one in your neck?
    The one my wife bought registers as expected on her, but rarely read over 90% for me. She got quite concerned about that, but I’m still here!
    thisisnotaspoon
    Does spO2 correlate to anything in exercise? e.g. does VO2 Max correlate to a drop off in spO2?
    I’m a geek and still fancy anew watch so this is my flimsy justification.
    mrbadger
    the issue with them is that they are only accurate to 2-3 % and the normal values are 95-100%.
    the one on my garmin watch is even more unreliable
    may be helpful if you are struggling to breath and seeing numbers in the 80s I suppose
    ratherbeintobago
    Funnily enough, we’ve been recruiting to the UK-ROX trial of standard vs. conservative SaO2 targets, and the EXAKT sub-study (which has not long closed) was looking at precisely that.
