Viewing 40 posts - 1 through 40 (of 41 total)
  • PSA- Don't bother with expensive front mechs
  • getonyourbike
    SRAM X7 2×10 Low Direct Mount Front Mech at 137g – £28
    SRAM X0 2×10 Low Direct Mount Front Mech at 130g – £56
    Double the price for 7g less weight and a different number written on the cage. Pffft…
    PaulD
    This gets even worse when you start comparing Shimano XTR, XT, LX/Hone/SLX and Alivio mechs.
    Price and weight are completely random.
    PaulD
    rs
    go 1 x 9/10/11
    binners
    Does anyone actually notice their front mech from one year to the next? Seriously?
    I don’t believe that there’s any discernible difference from Deore through to XTR, apart from some miniscule weight difference that could probably be accounted for by clipping your toe-nails before going out for a ride 😀
    maccruiskeen
    Is weight the only measure for comparison? Or are robustness, precision or longevity not factors. I’m sure plenty of people value prettiness over grams
    getonyourbike
    They’re almost exactly the same!
    X0
    X7
    hugor
    Ive hated every front mech I’ve ever owned. I can’t wait for a better solution but still retain gear range.
    jfletch
    My bike still has an Shimano STX-RC front Mech on it from 1998 the stone age which has been carried over from old bikes.
    Works fine, weighs about 10g more than a new one.
    idiotdogbrain
    Hammerschmidt?
    ell_tell
    I’ve got an original Shimano Exage on the front my old Saracen which still works fine.
    epo-aholic
    mmmm, since when did weight correlate with quality?
    cynic-al
    Same for 25+ years mtbing
    PiknMix
    fwiw my xtr mech definitely works better in both function and looks to my deore one.
    Rorschach
    4x betterer?
    Taff
    Hugor – there is a cranks system the was basically a chainring split into 4 quarters which expanded to move the chain. Think it was on here a while back, or maybe twitter but quite a clever solution
    Gunz
    I was cleaning my old Kona the other night and wondering why front mechs have got so portly and comparitively ugly. Look at a 1993 XT mech and it really is an exercise in pleasing simplicity compared to the modern stuff.
    molgrips
    Front mechs (unlike rears) get battered about and lose efficiency gradually, ime. So you think it’s fine and can’t figure out why it’s not shifting well, but it’s actually distorted and a new one will be spot on.
    I wonder if a better built one would last longer in this respect? No idea.
    Northwind
    Especially don’t bother with expensive SRAM front mechs!
    With Shimano, my experience is that higher spec ones are a bit more durable as well as lighter… But then, my SLX doubles are lighter than XTR triples, IIRC.
    CaptJon
    I could be completely wrong, but isn’t the quality of the shifter more important than the quality of the front mech? …in terms of shifting quality
    cynic-al
    Taff – Browning
    rp16v
    iv had a sram x5 on for 2 years now on my hardail paid £5 for it and it works happy days
    mikewsmith
    lighter = better
    cheaper = better
    whateverIwant = better
    It’s all subjective.
    njee20
    XX1, better solution than hammerschmidt I reckon.
    The old M952 XTR mechs were great, they had a parallelogram action and shifted really nicely. Noticed very little difference on newer ones though, and for a while Deore was the lightest!
    franciscobegbie
    Gunz – Member
    When I discovered that the SRAM front mech off my old bike wouldn’t fit onto my new 456 Evo, I resorted to bunging an 18 year old STX-RC mech on.
    Works great, is smaller and neater than modern mechs and works with a SRAM shifter too.
    PiknMix
    Rorschach – Member
    4x betterer?
    good point.
    No maybe x2 but then (and this may just be sheer coincidence) my deore one failed recently and the XTR is going strong, both are on hardtails and have had similar conditions.
    the most unscientific comparison ever for which I apologise.
    continuity
    Why would you want a front mech?
    Just why?
    Get fitter.
    WillC9999
    This argument takes us to a singlespeed which is not sane!
    binners
    Get fitter.
    No! You get fatter! 😛
    aracer
    Just to get back to the original point, AFAIK the M952 was the lightest MTB front mech Shimano ever made – the M960 was certainly significantly heavier. Sadly that was from the age when XTR was still non-compact, hence the lovely NOS E-type M952 I have doesn’t work with my chainset – I guess at some point I’ll give up on the idea of getting it to work and put it back on ebay before butchering it.
    njee20
    Yep, the E-type one had the carbon back plate too, was lovely! I think it was when M960 was current that Deore was the lightest. Daft!
    Saying that… having multi-pull etc has made things easier!
    ormondroyd
    My XTR mech has been on my bike for the best part of ten years. I definitely remember swapping out cheaper mechs because they developed play
    bigyinn
    A lot depends on the mech design with shimano.
    Top clamp / bottom swing seem to last a LOT longer than the bottom clamp / top swing which seem to go rattly a lot quicker.
    From my own experience the cheaper bottom clamp ones do go rattly a lot quicker than XTs. I’ve got a 10 yo XT top clamp that is still going strong with no play in it.
    continuity
    Or actually practical for much of your riding.
    But if you can race XC on a 1x drivetrain, race enduro on a 1x drivetrain, and race dh on a 1x drivetrain, and it is comfortable enough for general day-to-day stuff, I can’t see why anyone needs a front mech.
    getonyourbike
    I’ve actually come to the decision to go 1×10 and just change chainrings depending on what I’m riding. Screw a front mech, get a Sraitline Silent Guide 🙂
    nicko74
    PSA- Don’t bother with expensive front mechs
    This sounds like a Viz guide. As in “when your pet pig gets injured, just put bacon over the wound”
    “don’t bother with expensive front mechs, just shift the chain with your fingers!”
    loddrik
    Can’t see why anyone needs any more than 8/9/10 gears anyhow…
    br
    To reduce the amount of time you walk?
    molgrips
    You don’t necessarily, but the spread is handy. Are you new to this biking stuff? 🙂
    Er, you can do those things, and pros probably do. But they are pros, most of us are not. What a silly comment!
    thisisnotaspoon
    +1 for old mechs being far better
    On the other hand I was quite disappointed with my new SLX rear. Fitted an XT to the Pitch but got a SLX for the hardtail, lots of pressed steel where the XT was machined aluminum. The XT just didn’t look cheep.
    Will it be £10 better/worse? No idea, I rarely get long enough out of them to notice these days!
    oldgit
    I’ve not read this etc etc, but.
    The front mech does a huge amount of work, often shifting from 22 to 44 in one go. No easy life here like the rear mech. It’s amazing how many folk overlook the importance of this piece of kit.
    The dearer kit IME has been far superior on and off road.
    Except the mechanical bit, which isn’t the same at all.
    Also agree with top clamps being better. Plus with a top clamp you get less debris build up in the B/B area
The topic ‘PSA- Don't bother with expensive front mechs’ is closed to new replies.
