Protecting a new fr...
[Closed] Protecting a new frame - anyone used clear Gorilla tape rather than Helitape?
8 Users
As above really - I have a new frame on the way and have had very mixed results with Helitape before - peeling off etc, so idly wondered about using clear Gorilla tape instead? I'm not particularly precious about my frames, more thinking about preventing paint being rubbed off from frame bags etc - thoughts?
Posted : 21/01/2020 9:49 am
Yes, I have.
It did protect the frame well but the slightly serrated egdes collected dirt and made it look tatty AF. Was a pain to remove when I sold the frame too.
Wouldn't use again.
Posted : 21/01/2020 9:52 am
Used the regular thickness 1” wide for a custom steel frame (so no vizy kit for it to buy off the shelf). Not as hard wearing as the proper stuff but fine for just to take the general scrapes/transport scares.
Posted : 21/01/2020 10:00 am
Cheers chakaping - knew it would be a pain to remove, but didn't think about edges - good shout 🙂
Posted : 21/01/2020 10:01 am
As above, it's a lot thinner than the 3M stuff, and the edges look horrible.
Posted : 21/01/2020 10:07 am
try this:
https://www.demon-tweeks.com/uk/venture-shield-venture-tape-250065/
Posted : 21/01/2020 10:18 am
I whacked a load on a classy steel frame before a bikepacking trip. I can send you some pictures. It will put you off, it looks proper shit. It's a black frame, and I've used black leccy tape in some areas and that looks much better. I think I thought it might wear through over 70 miles of welsh winter mud.
Can't bring myself to tackle taking it off as I know it's going to be a pain. It gives people something to laugh at in the meantime!
Posted : 21/01/2020 10:33 am
Can’t bring myself to tackle taking it off as I know it’s going to be a pain.
Hairdryer will assist greatly with removal.
I only twigged that near the end of my epic ordeal peeling it off.
Posted : 21/01/2020 10:53 am
Seems just fine to me, if it's the clear gorilla repair tape you mean, which is a narrow roll compared to a fat duct tape style. No tatty edges (using scissors to cut), nice and thick, and seems to be lasting well. Bit of heat and it comes off fine.
Posted : 21/01/2020 11:06 am
Thanks all - have decided just to do what I've done before and bought some Helitape - hopefully have a better result this time! Might even have some left to do the areas on my Solaris Max where the last lot peeled off...
Posted : 21/01/2020 11:41 am
Need to get some helitape myself, what one did you go for?
Posted : 21/01/2020 11:45 am
Off ebay - an outfit called Paragon Tapes who do lots of different sizes. Only doing the main areas, so went for 2m at 75mm wide, which should cover everything I need. Although, after I did my Solaris, on the first ride out I put a big scratch on the one tube I didn't tape...
Posted : 21/01/2020 1:00 pm
I used Tesa's clear repair tape. It looked ok on the day, but the next day it had lifted all over the place. I'm sure it will do the job but as some point I will be peeling it all off. Pulling off a reel rather than backing paper makes it a whole load more faffy too.
Posted : 21/01/2020 6:49 pm
