new model, its identical to the 20/21 model.
i’ve just checked the geometry numbers on s/m/l/xl on the blueprint 2020 pdf versus the numbers above (non LT version) the only difference i can spot is you can get a different stroke shock/ (or coil shock) to make it 10mm bigger at the back..
standover height is new into the numbers too.
In theory i could buy the replacement shock and make my 150/140 2020 model an LT.
ps. buy a spare Y0000128 Kit Axle pivot £11-12, as the fixing ring is very easy to break on the rear axle,
pps. i’m not sure an extra 10mm at the back is needed, since changing the shock token to the biggest one, its felt 10x as good, and it coped very well in the granada mountains last week
