Depends on the sizes frame and cups and what the interference fit is going to be. I would measure both before installing. Sometimes the frame needs reamed to size, occasionally turn cups down if the frame cannot be reamed to size. Loose fits need to be bonded in. Loctite have a range of products depending on the level of press fit, gap size etc. Most retaining compounds soften with heat, so you can use a heat gun in the future to aid removal if required.
Permanently installing a press fit BB with replaceable bearings often sorts creaks. Screw together ones help with alignment if bonding into a really loose frame, just check internal clearance first.
I normally aim to follow the manufacturers instructions in the first instance unless there is a reason not to. One big brand frame manufacturer used to spec grease, but if it creaked then use retaining compound (as they did not appear to be able to control their BB bore IDs accurately enough for a reliable press fit)
