Home Forums Chat Forum Oceangate Sub Missing
Viewing 40 posts - 681 through 720 (of 1,073 total)
  • Oceangate Sub Missing
  • ratherbeintobago
    I suspect that there’s some research money about to be spent on finding out about the effects of extreme pressure on CF and titanium bonded structures.
    OTOH there’s plenty of experience with steel and Ti and when weight isn’t necessarily an issue…
    ernielynch
    What, even dolphins? No-one can hate dolphins.
    10 Reasons Why Dolphins Are A$$holes
    RustyNissanPrairie
    My money is on the bond between these two materials.
    thols2
    My money is on someone building a replica and testing it to destruction to find out what happened.
    1
    martinhutch
    Even that may not explain this particular failure – wouldn’t be surprised if there were multiple potential failure points.
    trail_rat
    if they found the two end caps – far apart as reported
    doesnt that suggest the carbon crushed and expelled the end caps during the inrush ?
    gobuchul
    Wouldn’t that happen regardless of where the failure was? Either in the main CF section or at the bond?
    sharkbait
    It’s the gelcoat, or what ever the high tech equivalent is, that seals the CF.
    Gelcoat is simply a coloured external finish to GRP and CF products.
    It can be porous after a length of time leading to osmosis in boats but I read that they covered the CF with a ceramic coating of some sort..
    2
    jameso
    its beyond me why anyone would want to go up Everest these days.
    “Because it’s there”
    Beyond me how people can listen to Adele but hey, we’re all different and that’s good.
    Keva
    The porthole was an area of concern…
    He said the window gets ‘squeezed’ as the craft gets down to 12,500 feet below the surface. If it is going to fail, the structure gives a ‘warning,’ he says in the video.
    But Rush admits in the clip he had “broken some rules to make this.”
    Asked what the window is made from, he says: “It’s acrylic – plexiglass.
    “It is seven inches thick and weighs about 80lbs. When we go to the titanic it will squeeze in about three-quarters of an inch and just deforms.
    “Acrylic is great because before it cracks or fails it starts to crackle so you get a huge warning if it’s about to fail.”
    Some experts believe the craft may have suffered a catastrophic failure due to the pressure underwater – with the window being a possible area of concern.
    1
    joefm
    What’s the point of a warning at that depth? Oh its crackling followed by  Instant death.
    4
    bikerevivesheffield
    Lots of know all’s on this thread
    bigdawg
    Iread this a couple of days ago…
    The acrylic window and the rigidity sensors, what did he seriously think he could do between the warning signs and getting back to the surface four miles above him…
    All his warning systems could do was tell him he was about to die..  Guy was seriously deluded…
    Keva
    it’d be a bit like rice crispies I guess… snap, crackle & pop. You’d probably have about half a second to think oh shit.
    crossed
    So does this mean that even when you spend £250k to go to the bottom of the sea in this death trap the view will be shit because the tiny porthole is deformed and distorts the view?
    3
    thegeneralist
    Lots of know alls on this thread
    FTFY 🤔
    1
    jameso
    ^ still missing a hyphen : )
    1
    Keva
    A colleague from work said today that the viewing is done from screens on the inside which are connected to remote cameras on the outside of the sub. So basically if that’s true you may as well just sit on the transport ship above and send down an ROV with cameras!
    gobuchul
    And that would of cost a lot more money and using that sub.
    2
    el_boufador
    I did think wouldn’t it be a lot less dangerous and also cheaper to create a sub which you don’t actually send down to the bottom at all. Really it’s just a glorified simulator but you don’t tell the punters that
    Put people in it, send it down 2m then on the screens and also through the porthole you just play vids of a previous mission.
    Jolt the sub about a bit to simulate movent.
    They did it on a much grander scale for the moon landings 😜 so can’t be too hard at this small scale.
    tomhoward
    Wasn’t there a TV show where they convinced contestants that they were going into space by doing pretty much that?
    Edit, yep:
    https://en.m.wikipedia.org/wiki/Space_Cadets_(TV_series)#:~:text=The%20series%20was%20a%20hoax,contestants%20did%20not%20leave%20Earth.
    martinhutch
    Yeah, Space Cadets on C4? Watched a bit of it yesterday on Youtube, were people more gullible in those days?
    mashr
    There certainly was – Space Cadets
    squirrelking
    Aaand we’re full circle, thanks for playing…
    el_boufador
    Haha hadn’t read the whole thread. Can see the sim thing already done ages ago on P2 🤣
    dirkpitt74
    Has anyone checked on Joe Cocker lately??
    1
    donks
    Heard he’s playing Glastonbury later
    dudeofdoom
    That DSV ‘Limiting Factor’a bit of a thing –
    The defining feature of the Limiting Factor is the 90mm thick pressure hull. Having been machined to within 99.933% of true spherical form, it is testament to the precision engineering required to develop a certified, reusable, full ocean depth submersible.
    It also rocks seats.
    trail_rat
    You utter Know it all.
    Klunk
    the fly tipped sofa has weighed in in the fail! dear god
    Lefties sneer. But those brave souls on the submarine died in a cause – pushing out the frontiers of human knowledge – that’s typically British and that fills me with pride
    most of the sneering seems to be coming from your readership mate going by the comments!
    ernielynch
    It might well be typically British but the submersible’s owner and pilot was American, and the expert on the Titanic, and who had done several previous dives to it, was French.
    British involvement appears to have been restricted to handing over rather large amounts of money.
    1
    thelawman
    Familiar, that.
    thisisnotaspoon
    Somewhat surprisingly weight is a massive issue on submarines.
    Because it’s fairly obviously got to float. But you’ve got to ballance that against making it as small as possible because force = pressure x area so the bigger it is the shallower it has to stay (or you need even more material). That’s why they’re all so crammed in. Space needs to be as efficient as possible. And by cramming everything in, you end up with something overall far more dense than a surface vessel, so everything needs to be lighter again.
    slowoldman
    I am frankly gobsmacked that with their previous experience Hamish Harding and Paul-Henry Nargeoulet would choose to go on this trip.
    CountZero
    Lots of know-all’s on this thread
    There’s lots of detailed information about the subject out there, from people who build these sort of structures; it’s really not difficult to find if you care to actually look.
    jonm81
    Some of us design equipment for submarines and subsea unmanned systems so yeah, there are some who know a bit on the subject.
    Daffy
    Weight is less of an issue than you’d imagine for  most large submarines.  Indeed it has far more effect on inertia and control than it does on buoyancy.  Most subs have substantial reserve buoyancy and ballast tanks and ballast weights are customised for each project, even when part of a production line.
    Several projects I’ve worked on were substantially over predicted weight but functioned fine in all but the most extreme circumstances.
    Also, substantial amounts of equipment are stored outside the pressure hull, so while they affect size and weight, they don’t alter the pressure hull sizing.  Thrusters, sensors, o2 tanks, ballast tanks, storage, etc are all in free flood areas.
    The conspiracy theories have started.
    https://stewpeters.com/video/2023/06/titanic-cover-up-rothschild-funded-ocean-gate-sinks-sub-to-hide-truth-about-the-titanic/
    (No, I haven’t watched the video. Reading the introduction was enough)
    “Did an iceberg really sink the Titanic?
    Google Whistleblower Zach Vorhies is here to talk about the missing submarine and his alternative theory about what’s really going on.
    When the media believes something is important and all have the exact same narrative that is a red flag the truth is being concealed.
    The lost submarine operation was initially funded by the Rothschild dynasty.
    Due to a new treaty citizens of the West will no longer be able to visit the Titanic wreckage site without a permit.
    This submarine operation was able to obtain a permit with an experimental sub design while using a wireless video game controller.
    Zach believes this tragedy will be used as justification to prevent anyone from visiting the Titanic wreckage.
    Zach also believes the Titanic was not sunk by an iceberg but rather an explosion.
    We know jet fuel doesn’t melt steel beams.
    Likewise, an iceberg cannot cut through a hardened steel hull.”
