That’s what the video showed, short take-off from a flat deck with rear exhaust swivelled full down and front fan full on, and full hover and vertical landing.
I can assure you that we ARE buying the C variant for our own use. (Why the F would we contribute this much to something we werent) It is STOVL (short take off verical landing) as when it is under its full payload it cannot take off verically. I can also bore you with why people seem to think it is crap but infact the STOVL versions are the ones suffering from the problems they balame it with. so the american buy crap and we are fine. 😀
The STOVL versions of both power plants use the Rolls-Royce LiftSystem the massive fan just behind the pilot, BAe Systems not quite British anymore but they provides rear fuselage and empennages, horizontal and vertical tails, crew life support and escape systems, Electronic warfare systems, fuel system, and Flight Control Software
Awesome bit of technology and probably the last manned fighter
http://www.raf.mod.uk/equipment/f35jointstrikefighter.cfm
The us Call it the JSF( joint strike fighter) but we reffer to it as the JCA( Joint combat aircraft) i can bore you with reasons for that as well!
The best thing is that due to my age if i go to uni and apply to be a pilot when i reach that age and i get selected and selected again and again twice more my job may be flying that beauty!
Very pretty corporate video BUT have they fixed the bits of it catching fire/melting issue when it uses it’s afterburner for any length of time, is the generator reliability sorted because the last thing I read was that it had a 10th the desired/planned life span and was an absolute sod to get at and if it’s anything like the F22 it’ll spend hideous amounts of time in the hanger being maintained/fixed.
What can you tell me about the autonomic systems on this aircraft and how they are at odds with the current modus operandi of the British military support to flying?
These issues are being sorted it has already been in dev lenger than the 22 and wont see service till 2018 sonnest. also lockheed designed the F-22 on their own with out us and now we are helping it will def work. You know they couldn’t have broken mach 1 with out our help? every time they went to correct its course the air flow was destabilised and it stalled. we were also working to break mach 1 but gave up and sent our plans the the US. they noticed that we had the WHOLE surface moving whilst they kept the same design of aileron. they put the two together and BAM
Should have gone with conventional carrier aircraft in my opinion, looks very high maintenance! Added to that, not very likely I know, but when they enter service what if there is a problem that grounds the type? Can’t run F18 super hornets off a ski ramp!
Typical UK defence project “yeah you can make some of the bits,you just need to buy 50 of em and accept being bummed as the price goes up” Oh and you need to build some aircraft carriers to suit them, its got more **** folding doors on it than the wickes and B&Q christmas sale put together
any questions just ask away!
Do you know what ITAR is ,
Further google yak 141 mega afterburner awesumz with russian stylee
Aye. Would have allowed buying Super Hornets/Rafales off the shelf if the F-35C (which is the CATOBAR variant) fails. No fallback if the F-35B doesn’t work out.
Not exactly being gentle when they set it down are they?
They say in the Air Force a landing’s OK
If the pilot gets out and can still walk away,
But in the Fleet Air Arm the prospect is grim
If the landing’s piss-poor and the pilot can’t swim.
yep and no Im not american and nor have i been informed of what the americans are doing exactly. Keep the questions vauge and non harmful and I’ll try and answer. (if there has ben a press release i can generally help you understand that) I can talk about the vauge details of the Suit the pilot will be wearing and his HUD if ya like
Yh and no. they will fly rotary off the decks whilst the RAF will be stationed off the ship. The forces will be mixed and socialise but putting a sailor in charge of a fast jet of that calibre aint happenin
oops no I need to correct my self there “. These are the nice chaps that fix the odd Lynx/Merlin/Sea King from time to time. Mainly found lounging in the hangar sipping tea and swapping dits of the night out before. The term itself is an acronym of Wet And Flaming Useless. It applies to any member of the Fleet Air Arm.” had to double check 😛
Yes the forces will be mixed; however, given the precedent going back to 892NAS and their Phantoms, a majority of the aircrew will be dark blue. Sharky Ward demonstrated that the RN is quite capable of flying fast jets effectively.
