Home Forums Chat Forum More shaving
Viewing 40 posts - 1 through 40 (of 49 total)
  • More shaving
  • cynic-al
    Tried a cheapo WS safety razor ad blades from Boots….the shaving experience was a bit crap (admittedly I didn’t have time to check out any videos on technique).
    Is it all down to technique or will I need to spend £100 on a pukkah razor and the same on 17 types of blades to find out what works for me?
    KINGTUT
    Yay is Al’s troll du jour. 😉
    cynic-al
    It’s 100% true Mike and not trolling at all. You can inspect my stubble & slightly blotchy skin if you need proof.
    KINGTUT
    But your 40 Al, surely you know how to shave by now? 😐
    thegreatape
    Is that the plastic one?
    cynic-al
    Aye.
    jools182
    tried them king of shaves azor things
    could not get on with them
    for me its king of shaves oil and mach 3 blades
    thegreatape
    Good technique relies on the weight of the razor, rather than scraping it round your chops. That plastic one lacks weight compared to steel ones, making it harder to get the technique right. A fella on youtube going by the name of mantic is often the default starting point for how to use them properly.
    TooTall
    Safety razors – the rigid SS of the razor world.
    Give it up and stick to modern technology. Some evolution is good.
    richcc
    Not sure about the nature of the troll but on face value – assuming you’re shaving your face? – then gillete gel and the 5 blade gillete razor will sort you out.
    molgrips
    Al, welcome to the 21st century. Just because something is old fashioned does not make it good – I know this goes against the aspirational STW grain but there you go 🙂
    Hehe 🙂
    cynic-al
    So the safety razor fanbois were wrong? 🙁
    sv
    Go for the ‘selection’ pack on The Shaving Shack for blades. I have the Wilkinson DE (black plastic over a metal body) its quite weighty and a longish handle. Did manage to pick up an old Gillette Tech razor but its quite small and light. My shaving rash has disappeared after two weeks on the new DE shaving regime.
    Twin
    M3 Power razor with Nivea sensitive shave gel. Ace. Better than any electric razor I’ve used and the blades aren’t too expensive.
    KINGTUT
    If you are serious Al, Gilette fusion and a good shaving gel is all you need.
    If you suffer bad shaving rash than try a sensitive balm.
    KINGTUT
    cynic-al – Member
    Were they on this forum?
    What’s bloody annoying about shaving is that it’s something you do for years without thinking about it. Mach 3 blades and Nivea shave gel.
    Then you hear someone on TV talk about shaving (on Richard & Judy about 10 years ago, then Alan Davies on QI, then stuff on STW). So when shaving, a boring task at the best of times, you recall these conversations and start thinking about how you’re shaving. It’s bloody annoying. Shut up!
    Mach 3 blades work fine. So use them.
    Hohum
    Almost certainly it will be your technique.
    You can not use a safety razor in the same way you used a cartridge razor or you will end up with a sore face.
    Check out some of the videos (you know you really want to deep down inside) and then give it another go 🙂
    rOcKeTdOg
    Beard, sorted.
    cynic-al
    I know how to shave fine (with modern stuff), just wanted to see if the old school method was as good as its proponents hold out.
    richcc
    Too subtle for me mate…. Didn’t pick up on a little dig against
    [*] singlespeeds
    9 speed cassettes
    Hard tails
    Risers
    Flat bars
    Rigid bikes
    Sussers
    Delete as appropriate
    Hohum
    It is!
    You just have to unlearn all of your bad habits and start again.
    jools182
    you should try the oil though
    its loads better than foam or gel
    ton
    **** blokes talking about shaving……….wtf.
    mtfu the lot of you…………. 🙄
    what next…………’what moisturiser’………ffs
    KINGTUT
    cynic-al – Member
    I know you have a love of things vintage Al, but seriously as per Tootall above, some evolution is good.
    KINGTUT
    Well it is a far more manly conversation than asking ‘what bicycle should I buy next?’.
    nickc
    [bows in front of cynical-al/]
    Ace trolling sir, you are to be commended.
    I see Ton agrees with me, but in his own lovely way 😉
    CaptainMainwaring
    cynic-al – Member
    No they weren’t. After the other long thread I invested in a Muhle razor, brush etc. Still in my first week but a few comments on the experience so far;
    1) Get a much closer shave with the Muhle. Can’t believe how smooth it feels
    2) Takes about twice as long to shave, but 90% of the time not an issue for me
    3) Quite like the whole ritual
    4) Now on 4th shave and getting the hang of not looking like an extract from the Texas Chainsaw Massacre
    Reckon you need to go the whole hog of decent razor, brush, bowl so not cheap to start, but blades 10p each as opposed to over £1 each for the multi blades I was using
    Hohum
    Hooray!
    Another convert!
    Keep it up Captain 🙂
    LsD
    Ye should just go with waxing, Al………..it’s worked for yer scrotum for years!! 😉
    Mekur from http://www.gentlemans-shop.com/ , decent quality brush, sorted.
    soobalias
    gillette blue two – the best a man can get.
    ononeorange
    Absoluitely detest shaving – I think it’s a waste of time. So I use the cheapest nastiest blades I can as a kind of protest – why waste money on a pointless thing? Kind of works for me in a weird way, although there are very “bloody” days.
    Ho hum – Member
    Hooray!
    Another convert!
    This is the weirdest thing – What does it matter to you how someone else shaves???
    carbon337
    Babylis i-stuble electric jobby works for me – never go clean shaving just take stuble down to .5 mm a couple of times a week.
    Jamie
    *skip to the end*
    Grow a beard.
    cynic-al
    OK:
    1. Who’s borked teh formatting?
    2. I am not trolling.
    3. Captain Mainwaring – how can the shave be that good if you are still cutting yourself?
    Hohum
    DezB – Member
    Ho hum – Member
    Hooray!
    Another convert!
    It doesn’t.
    In much the same way that I am not really bothered about whether or not cynical Al can get the hang of using a safety razor or not.
    Lighten up mate. It’s just a bit of fun 🙂
    anotherdeadhero
    = stick lump of roofing lead to plakky razor. Job done.
    missingfrontallobe
    KoS gel & 24/8 aftershave balm here, and using one of those Azor razors, mixed results with that one though.
The topic ‘More shaving’ is closed to new replies.
