Yep I’ve got last years RR.
I’ve had quite a few issues with it! The MIND system was dead on arrival and it had to go back to be tested and eventually replaced – I was without the bike for 9 weeks. The headset bearings went a few weeks after I got it back as it’s got headset cable routing which is not sealed in any way! There are now rubber grommets available to buy aftermarket to sort that. The Fox Transfer then seized up, which is apparently a common problem, so no a bike issue as such. Then after about 350K the link started creaking, annoyingly so, I stripped it down and 6/10 of the bearings were shot and a spacer was missing.
Personally I’m not sure that I’d buy another Mondraker, they don’t seem to be built / sealed well enough for UK conditions.
It’s actually a good bike when it works, climbs very well and I’m just starting to dial the suspension and it’s getting pretty good on the downs, now running a fair amount less pressure than recommended and I’m about to swap to a smaller volume spacer.
I didn’t get on with the 30mm stem, it just felt very twitchy, so swapped for a 40mm I had lying around and it feels much better to me now.
I bought it to replace my Cotic Jeht which is a great bike, but a bit too much heft and travel for my riding, I wanted something lighter, less travel, more trail oriented – a year later and I’ve still got the Jeht and a decision to make…..
