I’m getting an intermittent Engine Management Light. The code is to do with mismatch between the lambda sensors either end of the Cat. It only happens if the car is trickled along on the motorway for long periods – more adventurous driving and its fine. (it came up driving down to the Alps, then on the way back again. Thrashing round the cols it was faultfree)
It could be sensor error, or it could be a slight leak in the Cat body near the sensor (its a 20 year old car). With the engine running, I “think” I can feel a slight breeze on the back of my hand, but only slight and there’s so much noise and vibration under the car its difficult to determine much
I’ve got the cat off the car, the possible location of the leak is hidden from view by a welded on heat shield, so I figure some kind of pressure test is the way forward.
The easy solution will be to seal one end and fill it with water. Will this damage either the cat itself, or the lambda sensors? Plan B will be air pressure, but I’m not sure I can figure a way to seal both ends well enough for that AND attach a track pump!
Thanks
J
