All day I have been getting intermittent really nasty pain in a specific point on the outside of my calf. Cramp is not something I have had for decades so I am not sure but it maybe feels like a cramp pain. But its a very specific point high up on the outer part ( but not on the surface) not in the main muscle, it goers away and comes back again lasting only a minute or so each time. Maybe a dozen times since 6 am this has happened. Calf is not red or swollen.
thoughts?
I’m just feeling paranoid. No you cannot have my bikes! 🙂
Does the pain prevent you from moving your ankle? In my experience calf cramp basically locks my ankle in a a fixed position that you have to flex and extend forcibly to make go away.
Doesn’t sound like cramp to me – at least not how I’ve experienced it. I tend to get cramp when my leg is in a certain position or making a specific movement and it doesn’t repeat like that.
The pain goes away with pressure on the point and / or moving around. I think its in one of the muscles that moves the toes. Only lasts 30 seconds to a minute and has also gone away spontaneously.
its the reoccurring thats got me confused. DVT would be continuous and you would expect swelling and redness./ Cramp you would expect to be once and gone maybe leaving residual soreness.
Its still doing it today – but less painful and easier to get rid of with pressure and stretches. I think I have found the stretch needed but its weird as anything.
NHS 24 are not that bothered – referred me back to GP. No PE, unlikely DVT
They are not clinicians, they just follow a criteria. If you had said it was a continuous pain, probably would have ended up in A&E.
Avoid 111 and direct to GP or A&E for the win.
Could you have actually torn a muscle? Is possible to do without realising it, but then you would expect different movements and pressure to change the pain level.
Funkydunc – in Scotland they are clinicians. I spoke to a senior nurse practitioner. IT is NOT for A&E. If I had breathlessness or obvious swelling or redness or continuous pain then yes.
Muscle tear is a possibility I guess
GP called back to triage. 2.30 appointment just to check
I had a bit of a sore calf last year. I was having a couple of weeks off running so thought it was the muscles complaining about being un loved and un used.
It apparently was a DVT which then became a PE which then got infected which then resulted in blue lights and 5 days in ICU plus a bonus 5 in the Coronary unit as it had stressed the heart.
They told my wife I may not be coming out…
Get a D-Dimer test as soon as possible. Just to be certain as the food was horrible… Phone consultations are not really much use in these circumstances.
I’ve had two DVTs that didn’t show classic symptoms. The second one resulted in a PE as the blood test was a false negative. Don’t risk it, get a Cat or ultrasound scan. Hopefully it’s just cramp.
I must say I would have thought a dvt would be a constant pain and swelling which you don’t have. I’ve always got pains in my calf tbh, usually just a slight muscle strain.
But if concerns follow the advice above and go see a professional. Best of luck.
2 hr wait minimum as we wait for blood results. Ffs i am becoming a frequent flyer. At least this time i do not have to show my arse to everyone but its tempting to do it just for the hell of it
That’s one of the reasons my situation turned so serious. I left A&E with a jaunty fkc em and nary a backwards glance. It didn’t prove to be the wisest move.
Yes it’s horrible in there but that’s your only route in. Even the ambulances wait multiple hours outside so that would be no betterer.
I was not in A&E. Its a service where GPs refer for urgent testing.SDEC – same day emergency care. Different to both A&E and Minor injuries. GP has access to refer you there or to minor injuries. Minor injuries is not a walk in service here – you need a referral from NHS 24. We also have urgent care as an out of hours service adn AMU which is a GP or ambulance admitting service
4 hrs wait for a negative D-Dimer test so sent home – not even a scan. “Its muscular spasm”
Good news on the negative for claggy blood. Now stop whinging and get yersen home ya mallingerer!
At least you know (apart from that false negative up there^ Who knew there was such a thing?) and can consume Brufen in industrial quantities to get rid.
