Going to leave it like this for a while now, but I want to try a winged grip at some point. Ergon GS1 or SQlab 710. I wonder if the shape and wing would make up for going back to a lock-on.
Finally got round to trying a winged grip (SQlab 710) and I think they’re even better than the Wolf Tooth Karv silicons.
They were noticeably more comfortable over broken and root-cracked tarmac. Rather than get a spike through your hand it feels like you get some pressure and then you feel the front tyre deforming taking the brunt of the hit. On slightly rough stoned bridleways and farm tracks it might be that the damping of the silicons is more effective than the weight distribution of the wing.
I chose that grip over the Ergon GS1 Evo as the more sculpted shape looked like it’d be more effective. Pretty difficult to fit as the inner bore was undersized by 0.5mm with the lockring attached, took a lot of prising with a screwdriver. They add 2cm to the bar width overall. The wing angle is indeed important, too high up and your palms can’t brace against the rear of the grip. I wouldn’t try them on a MTB for steep terrain as depending on body position and slope angle you could find the wing impeding your ability to hold the bar.
Having switched from silicon push-on grips to the the Ergon GS1 Evo on my Ritchey Kyote bars, I wish I’d done it years ago. The difference is phenomenal
Thanks for this, I was happy enough with the silicons but this convinced me to try winged.
