ok so i HAVE to attempt this job at the weekend…hopefully without it going tits up!
i think i can cover the basics, ie height etc and position…
but a few things im a bit stuck on is when doing the L screw, which gear to be in? and the same for the H screw….
also as im putting a new cable at the same time, what do i need to do at the shifter end? fit the cable first, or do the H & L screws and do the cable after? also with the barrel adjuster does that need to be wound in clockwise or anti clockwise all the way or the likes?
a step by step guide would be most helpful if anybody can help 🙂
i did my rear mech before from help off here and never had any issues since, so hopefully you can steer me in the right direction with the front 🙂
thanks!
