Home › Forums › Bike Forum › Hot Wax Curious
- This topic has 55 replies, 26 voices, and was last updated 1 month ago by ant77.
Hot Wax Curious
b33k34Full Member
down another rabbit hole…and now I’m hot wax curious. ZeroFrictionCycling seems to think Silca Hot Wax beats everything and I see they now have a complete system including a heater/hanger and even a magic ‘chip’ that means you can work from a factory greased chain. And you can top it up with their drip on lube between wax dips.
but looks less effort that my current Smoove regime.
Am I right in thinking that these hot wax lubes are clean to the touch? ie, handling changes is no worse than with smoove? Other than cost are there any downsides? Has anyone gone back to regular lubes?
BadlyWiredDogFull MemberYes, stuff like Molten Speed Wax and, presumably, Silca are clean and smooth to the touch, no oily, grimy marks etc.
The Silca system is ingenious, but really expensive as per all Silca things. The main pro is the chip thing, but if you look at Zero Friction doodah, they’re now suggesting using Ceramicspeed’s chain degreaser to clean factory lube off new chains, small amount of it sorts multuple chains, which offsets the stupid price. Then just use a cheapo 15-quid slow cooker and whatever wax you like the look of.
I’ve never used the Silca system, but it does feel like the main advantage is the Strip Chip convenience, but using the Ceramicspeed stuff is really quick and easy and a lot cheaper than the Silca system.
I wouldn’t personally go back to conventional drip lubes, once you get beyond that weird cultish obsessive stuff that some chain-waxers seem to get sucked into, it’s really clean and very simple. That said, I’m not sure it’s optimal in a really wet, super gritty environment, like the Dark Peak over winter.
goodgriefFree MemberI’m on the GLF wax from Daz. It’s extremely low effort, the only faff is waiting for the wax to melt and then removing before it gets too hot. It’s not something to do just before a ride!
stevehineFull MemberI use GLF Wax (half the price of Silca) and a beauty wax melter which has digital temp controls on it. The only time I’m not completely happy with using wax is during the depths of commuting; where rain and road salt can cause rust problems on the outside of the chain. I did experiment with putoline and while it worked; I find the more “just wax” variants much cleaner to work with !
b33k34Full MemberZFC videos are incredibly long, as are the docx. Is there a summary of their advice somewhere?
I’m guessing the ceramic speed degreaser is the UFO drivetrain cleaner? so its’ a bit cheaper than the Silca prep solvent but not massively.
I’m guessing if you start with a completely new drivetrain it’s only the chain that needs degreasing, whereas if everything is covered in, say, smoove residue you need to clean the chainring and cassette as well?
nickcFull MemberAnd you can top it up with their drip on lube between wax dips.
I hate to be that guy, but doesn’t this sorta defeat the justification for hot wax treatment? That it lasts without having to do top-ups? I mean if you’re going to have to do this in between the faff* of chain removal, treatment and refitting…why not just skip that part and drip apply more frequently..? Plus the fact that high-end 12sp SRAM chains are recognisably insanely long lasting – even with just regular drip lubes, hasn’t this [expensive] bubble been burst now?
*Different personal levels of acceptable time involved in chain lube treatments notwithstanding
This is bicycles, I think we’re sufficiently ‘among friends’ here that we can admit that secretly we know and accept; it’s all a bit cult adjacent
13thfloormonkFull MemberIf you’re starting with a completey new drivetrain you can buy pre-cleaned chains from the likes of Inaspin.co.uk who also sell Molten Speedwax products.
In fact, if you want to dip your toes, you can buy pre-cleaned and pre-waxed, so you can try it for a couple of weeks before taking the plunge with the rest of the kit.
Personally I do really rate it although you pretty much have to take the extended drivetrain life on faith unless you’re super dilligent about cataloguing chain wear etc.
Not so sure about it for gravel riding, I wouldn’t be confident of a waxed chain lasting the distance of a long wet gravel ride, although I got at least 4 hours of pouring rain, river crossings and mud out of one application of MSW, just couldn’t be sure how much was left!
b33k34Full MemberThat it lasts without having to do top-ups? I mean if you’re going to have to do this in between the faff* of chain removal, treatment and refitting…why not just skip that part and drip apply more frequently..?
so, my reading of this is that taking your chain off and hot dipping it means it goes back on clean, and it can be good for some (many?) 100’s of miles BUT can suffer if it’s really wet/muddy. That’s fine at home, but not a lot of use if you’re on holiday. So having something that I can apply a couple of times while I’m away solves one of my main barriers to waxing now.
interesting. I’ve only had Shimano 12sp drivetrains and (unlike 11sp) seems to be a much stronger recommendation to only use Shimano chains. Which I’ve not found lasting very long with Smoove.
nickcFull MemberI’m not sure Eagle chains and Shimano cassettes play nicely together, so it may be moot.
big_scot_nannyFull MemberI’ll add, perhaps helpfully, that I’ve had real issues with top end SRAM 12spd chains and hot wax (in my case I am a 6yr now user of putoline) – it just never really got into the chain, would suffer frequent multiple stiff/seized links as a result. Works well with XT chains though.
OnzadogFree MemberI moved from Smoove to Silca Hot wax. I’ve tried Putoline before but found it too soft and gets manky easily. I wonder if Putoline uses the same slack wax base as Smoove.
I was getting really good drive train life out of Smoove so don’t expect it to be much better on Silca.
I solvent cleaned my chains pre waxing as this was just before strip chip and their pot were released. A solvent clean means my cheap Crockpot set up works as I’m not having to get to 125°C. Instead, I can wax around 75°C.
I’m running three chains per bike in rotation so I bull wax give chains when they need it.
For holidays, I plan to use Silca super secret to top up if it’s dry, or Smoove if it’s wet. Smoove is better for longevity when using the hybrid approach but is a different wax base so may contaminate your pot on rewaxing.
If you need to lube mid ride and can’t allow drying time for a drip wax, then Silca synergetic is said to be the best stuff.
I’ve now moved into a two pot system. The first “dirty” pot is around 100°C to melt to old wax off (no swishing in the pot), then move to pot 2 with clean wax to swish the chain at 75°C.
I’m switching chains early, when the rollers get a bit of movement rather than waiting for a squeak.
That’s two or three peak rides in the summer and one in the winter.
I wipe down with a microfibre cloth and IPA after every ride. But then I’m a self confessed maintenance tart.
13thfloormonkFull Memberswitching chains early, when the rollers get a bit of movement rather than waiting for a squeak.
Interesting, how do you test for ‘movement’?
As in spinning on the pins or just dangling loose?
nickcFull MemberI’ll add, perhaps helpfully, that I’ve had real issues with top end SRAM 12spd chains and hot wax (in my case I am a 6yr now user of putoline) – it just never really got into the chain
@TJagain – The King of Putoline, I think suggests that it actually works better with cheaper chains, that don’t have so fine a tolerance as the wax has somewhere to go, and stays there for longer. I don’t want to put words into his mouth, but I’m fairly sure that’s his current thinking.thisisnotaspoonFree MemberI’ve just switched from putoline to a DIY wax.
Chain cleaning, yes it does seem to work better with a degreased chain. Give it a good wash in white spirit, then in degreaser, then in meths (or boiling water). It (IMO) doesn’t need washing again, just drop it in the wax, sure some grit might get recycled back into the chain, but it’s diluted into insignificance. Probably worth cleaning if you’ve added wet lube though but I’m not sure either way (it’s only something I’ve had to do so infrequently that I couldn’t be conclusive about it.
You do and you don’t.
The wax outlasts everything else. That’s not up for argument, it just does. Which means on almost every ride it’ll last to the end, whereas oils or drip waxes wash off before the end of at least some rides regularly and I’m sure it’s those last few lube-starved miles that wear out the drivetrain. And for most people it’s 5-10 days out between applications, not a top up every ride like bottle lubes. If someone finds wax to be a faff then I’d question how effective their current lube is in the conditions that make wax a faff.
Does that mean it’ll do the Dirty Reiver in a bad year with no top ups? Possibly not. But:
1) that’s once a year for some people, and never for most people.
2) you’ve still probably made it to the 3rd feed stop without having to top up, whilst your friends stopped at 10miles to begin the ineffectual topping up with finish line gold. And at that point you’re battling against a soaking wet chain so anything you add is just going to form an ineffective emulsion* that lasts minutes.
*Or worse, it’s so hydrophobic that it just doesn’t cling to the wet metal at all.
It’s like saying “what’s the point in inflating my tyres, if I get a puncture anyway I’ll just have to re-inflate them anyway I may as well just ride on a flat tyre (or with a dry chain)”. You’d still run an inner tube / tubeless. And I’d say I probably have a ride (or weekend biking trip) where putoline washes off about 1/5th as often as I have to plug a puncture, but punctures aren’t an argument against owning a pump.
branesFree MemberI’ll add, perhaps helpfully, that I’ve had real issues with top end SRAM 12spd chains and hot wax (in my case I am a 6yr now user of putoline) – it just never really got into the chain, would suffer frequent multiple stiff/seized links as a result. Works well with XT chains though.
Possibly related I had terrible trouble with 12sp flat top waxed chains in muddy cross races last year, to the point that I abandoned them completely. At the time I just put it down to flat top chains, but I have been wondering since, as few others seem to have had trouble with them. Wondering now whether it may be worth some more experimentation with non-waxed flat top.
ant77Free MemberI’ve just bitten the bullet on this one for my road bike. Literally first ride on it today after waxing at the weekend.
After the intial ‘badly adjusted derailliuer’ noise it then quietened down and was lovely for the rest of the ride.Have also put a waxed chain on my turbo bike with the prospect of 5 extra watts of friction released from the drivetrain… Marketing BS, but as I get a breakdown of my power at the end of every race I thought I’d try. Each race is different, but my sustained power over 3min to 30 minutes was in the region of 3-5w higher than my previous 30 day best. But, each race is different so we’ll see.
There was a pile of wax under the bike though after the first ride…I used a crock pot. Initially I started off thinking I had white spirit, alcohol, meths etc in the shed. But even on a new chain I wasn’t sure if it was actually clean of the factory grease. So when you factor in how much it costs for multiple baths of the stuff, vs the Silca chain stripper (and the fact that will do 15 chains) I went back to the shop and got some and was up and waxing within half an hour.
Long term, interested to see how it works over multiple rides. If the road bike works well, then next one will be MTB where rides are shorter but conditions harsher.
greyspokeFree Member@stevehine if you want “just wax” then put beauty wax in your beauty wax melter. Wax sold for recreational purposes is the same stuff. You can raise the melting point by adding candle wax, lower it by adding clear lamp fuel.
OnzadogFree MemberInteresting, how do you test for ‘movement’?
Still a work in progress really. Run my finger along the bottom side and see if they roll easily and then ping it sideways and listen to see if it rattles
stevehineFull Member@greyspoke – I just meant a chain wax that was more “wax+ additives” that dries clean to the touch rather than putoline which always left a sticky coating for me.
BadlyWiredDogFull MemberZFC videos are incredibly long, as are the docx. Is there a summary of their advice somewhere?
https://zerofrictioncycling.com.au/wp-content/uploads/2024/06/Chain-prep-Guide-Concise-v3.pdf
and
https://zerofrictioncycling.com.au/wp-content/uploads/2022/05/CHAIN-Prep-FAQ-Guide-V2.pdf
Under the ‘instructions’ tab on their website. HTH. And yes, there’s a lot of flannel on that site, but also a fair bit of usefulness.
jamiemcfFull MemberI’ve waxed my eldests 7speed chain on his 20″ bike. Keeps it clean to touch. I don’t think he cares about any performance benefits
13thfloormonkFull MemberNot-so-stealth ad, I’ve got a block of GLF I’d be glad to pass on for postage.
I switched to MSW to see if it was more durable on wet gravel, jury’s still out on that but GLF was definitely good for road bike use (and smells lovely haha!).
jimdubleyouFull MemberA “just waxed” 12speed chain (shimano/the Silca stuff) did a 600km (mostly dry ) tour on my road bike earlier this year. I took drip on wax and some of the “mid-ride” top up stuff but didn’t need to use either…
Also did a 500km off road race on my 11speed gravel bike – it wasn’t dry for all of the race and it needed a re wax/top up at the end…
1goldfish24Full MemberI’ve waxed my eldests 7speed chain on his 20″ bike. Keeps it clean to touch
oh good, not just me then that wondered if I was disappearing into a hole of madness as I degreased my 3 year olds chain. It’s put an end to that that “ooh no don’t touch that bit or you’ll have to wash your hands / put your trousers straight in the wash”.
uponthedownsFree MemberThis spring and summer I’ve been using paraffin wax bought off ebay applied using a small wax pot used for hair removal. Nitro cellulose thinners are great for removing the old lube from your chain, cassette and chainrings before wax application.
So far its been great. Lovely doing a bit of bike maintenance and not being instantly covered in black crap from the chain. I bought a second chain and am rotating them. So far I haven’t had to clean a chain before re-applicaiton of wax but if you need to then heating it in boiling water will get the old wax and dirt off. Just make sure its properly dry before re-waxing.
Of course real test will be how well it survives Autumn and Winter.
OnzadogFree MemberI’ve been cleaning waxed chains by dropping them in an old drinks bottle half full of warm water and a little squirt of fairy. Thoroughly rinse, quick blast with a hair drying and wrapped in a microfibre towel until I fire up the wax pot again.
oceanskipperFull MemberI switched to MSW after trying GLF as I thought the GLF didn’t last as long, no real scientific evidence to back this up mind you just didn’t seem to handle the wet as well. Both need redoing after a wet ride but the MSW seemed to tolerate a ride on damp roads better. I’ve got X01 SRAM 12 speed and I never used GLF or MSW when I had Shimano (only Putoline) so I can’t compare how well it gets inside the chain. Interesting that people think the wax doesn’t penetrate. I can say that after wearing out an SLX chain in 300 miles with a drip on lube that XTR and X01 both have lasted over 2500 miles with zero wear using Putoline/wax. In fact I’ve not worn one out yet as I’ve sold the bike first!!!
13thfloormonkFull MemberSaw an email from Silca advertising some new additives including ‘Endurancechip’ which you can add to existing wax to increase lifespan.
Very tempting to be honest, granted it’s another £30 but I would expect to get quite a few waxings over two bikes out of that. Just wondering how bad an idea it might be to chuck it in with my MSW…
cookeaaFull MemberI’ve been using putoline a while, I did experiment briefly with some DIY wax (literally melted candles with a splash of oil and a dob of grease in) which worked, but I have found putoline to last a while. I do have to admit it can be a bit messy if you don’t meticulously clean the outside of the chain and in-between links, which has me considering another go at a DIY wax recipe or maybe trying GLF (which is currently out of stock).
Maybe even a bit of a hybrid? Mix some putoline into a paraffin wax for the additives? And/or molybdenum disulfide or graphite?
13thfloormonkFull MemberSee above, I’ve got some GLF to move on for postage costs…
1el_boufadorFull MemberYep I’ve been waxing chains for a few years now..hands down way better than lube IMO. I’ve tried putoline but prefer my homebrew as it runs cleaner. Doesn’t last as long though.
My homebrew recipe is roughly 3 parts paraffin wax to 1 part bees wax, and a good dollop of grease. I tend to make up a new batch of wax every year.
It’s really, really cheap after the initial outlay for whatever wax melting device you use ( I use a deep fat fryer)
I have 2 chains per bike and rotate them. Usually means I am re- waxing a few chains at once as a batch which cuts down time taken.
I strip the factory grease off the chain using white spirit. After that I never bother cleaning a chain I just dump it in the wax. All the crap falls to the bottom of the fryer. Whip the chain out, wait a few mins for the wax to solidify slightly then wipe the chain with a rag.
If I’ve been on a wet ride but the chain is still ok, I’ll sparingly spray a bit of gt85 on the chain to keep surface rust at bay.
Drivetrain seems to last absolutely ages
Never going back to normal lubes
b33k34Full Memberconfused by your approach – you’re mixing (some kind of) grease into your wax? but cleaning the factory grease off?
And you’re spraying with GT85 – isn’t that contaminating/dissolving your wax?
el_boufadorFull MemberI got the recipe off a forum, I can’t remember where, years ago. It’s only one big ish dollop of grease (3 tablespoons?) in a small fryer otherwise full of wax.
Only spraying with *a bit* (very sparingly) of gt85 after wet rides.. otherwise get surface rust.
Might be dissolving some wax I suppose.
¯\_(ツ)_/¯
Works for me
113thfloormonkFull MemberOnly spraying with *a bit* (very sparingly) of gt85 after wet rides.. otherwise get surface rust.
I spray it on a rag first and run chain through the rag, keeps the chain looking lovely and clean and keeps rust at bay. Can’t see how it would remove any of the important wax inside the links
nicko74Full MemberI’ve got a new 11 speed chain to wax this week while the OH’s away. I’ve never got round to getting a chip fat fryer for it, just heat the tin on the stove, carefully place chain in, shooffle gently for a few minutes, carefully take out, leave to dry on cardboard.
Dumb question, how vital is it to degrease first with meths/ white spirit etc? And how thoroughly are we talking?
HazeFull MemberYou don’t want the factory grease contaminating your nice new wax.
You only do it once so it’s not worth cutting corners, I think mine had an initial soak in a degreaser beofre a couple of white spirit baths with a further couple in methylated spitrits to finish off.
13thfloormonkFull MemberDumb question, how vital is it to degrease first with meths/ white spirit etc? And how thoroughly are we talking?
Just because you mentioned heating a tin, is it Putoline or something like GLF, MSW or Silca?
The beauty of Putoline in my experience is that no cleaning is required, but the true wax blends definitely need it I think. I guess over time the old oil/grease would mix with the new stuff so it would probably come good in the end but I bet it starts off a bit of a sticky mess.
nicko74Full MemberPutoline (or, as some wag on another thread called it, Plutoline!) – a tub I’ve used 5-6 times over the last 3 years or so.
