I do have a handful of hue lights and a hub so it’s an option, but specifically for these two lights in the hall, a hue replacement is not really feasible unless I replace the whole units. The problem I have, is that one of the lights is connected to the switch, the other, has no switched live so I can either wire into live for permanent on, or leave disconnected for permanent off (as it has been for 2+ years).
My thinking is I can put something like a Shelly 1 Mini in the problem light, and use it to turn the light on/off over wifi. But then I need a way to control the Shelly unit. Obviously I could set up something in HA and use my phone, but it would be nice to have it controlled from a physical switch for ease.
So that leads me to, 2x Shelly 1 mini, one in each light in the hall. Then some kind of a switch on the wall to replace the current switch entirely, when you press this new switch, it sends a command to HA which then triggers both Shelly’s to turn on.
Previous house had an old galaxy tab on the wall for all things Smart Control, but in this case I would really just like some kind of semi traditional switch.
