Home Forums Chat Forum Help fix my hole (roofing content)
Viewing 15 posts - 1 through 15 (of 15 total)
  • Help fix my hole (roofing content)
  • stonster
    Have some scaffold on the house for another job.  Whilst up there, examining the eaves and found this:
    Looks like the bottom piece of mortar has just fallen out.  Any thoughts on a good fix?  Guessing maybe fill with repair mortar?  But presumably would need something to keep it in place whilst it dries?
    Any ideas?  Have got a big tub of this: http://www.platinumchemicals.co.uk/products/soudal-cement-repair-express kicking around
    bails
    The mortar should be resting on cement board, that’s the sheet underneath the mortar that’s still in place. You’ll need to replace that and then put the mortar in.
    singletrackmind
    Might want to repaint the soffit boards whilst the scaffolding is up
    dooosuk
    Remove all the cement board and mortar and spend 30mins fitting dry verge and you won’t have to keep patching it up as bit after bit fails.
    airvent
    The cracked cement sheet holding the pointing up is called under cloaking, you can buy this from builders merchants. That then supports the mortar pointing, make sure you don’t use a very wet mix or it’ll shrink when it dries and fall out!
    Re: dry ridges they are lower maintenance but still have habit of blowing off in high winds and they don’t look as nice in my opinion.
    n0b0dy0ftheg0at
    the-muffin-man
    Flexim Roof Putty is ideal for this sort of problem…
    What is Flexim
    1
    stugus
    Likely to be asbestos cement under-cloaking by the look of it.
    stonster
    Wow – under cloaking. Who knew that’s what it was called. Every day is a school day
    stonster
    Next question then – how do I cut under cloaking board?!
    duncancallum
    Depends if it’s asbestos or not….
    stonster
    I’m thinking the repair piece I buy from the shop hopefully won’t be 😉
    nealc
    Score and snap with a Stanley knife I would have thought.
    trail_rat
    What is Flexim
    Exceedingly expensive is what it is.
    duncancallum
    A multi tools ace for jobs like that.
