We have a Grant outdoor 21kw combi
I think you’ll struggle to run a shower.
We have a Grant 36kW combi for this very reason. It runs a very good, hot shower.
We had a 22(?) kW LPG boiler that didn’t really cope with showers. The only way to make it acceptable was to really restrict the flow, and even then, the shower wasn’t as hot as we would like, especially with colder incoming water during the winter. The problem with restricting the flow is that it becomes a balancing act between getting the shower hot and having enough flow to keep the boiler on.
The Grant combi will be better, as I’m pretty sure it has a heat store, so you’ll get a hot shower until that runs out, then it’ll run colder.
