Google Nest Protect...
[Closed] Google Nest Protect - possible to use as heat sensor only?
8 Users
Looking at replacing current smoke and CO alarms with Google Nest smart products. Does anyone know if it is possible to switch off/disable the smoke detector on individual devices, and use only as heat detector? Thinking specifically for kitchen use.
Posted : 08/04/2021 3:59 pm
Apparently not. This is an issue due to the new legal requirement to have a heat detector in a kitchen that is connected to other smoke/heat detectors. AFAIK there is no solution yet.
Posted : 08/04/2021 4:04 pm
Nope, you can't even temporarily disable the detection if you know smoke's about to be created (I had this issue with a plumber doing some soldering near one of mine, had to temporarily take it down and move it until he'd finished in the end)
Posted : 08/04/2021 4:13 pm
Hmm... OK. Any recommendations for a smart heat sensor, or should I just not bother?
Posted : 08/04/2021 4:15 pm
We have one (of 3) in the kitchen and haven't suffered any issues with smoke triggering it.
Posted : 08/04/2021 4:17 pm
We have one (of 3) in the kitchen and haven’t suffered any issues with smoke triggering it.
Am I the only one that sees the issue here ?
Posted : 08/04/2021 4:24 pm
Mine only gets triggered by smoke in the kitchen if I'm doing a big stir fry and forget to put the extractor on max. I think I'd rather have smoke detection and the occasional false alarm then heat only.
Posted : 08/04/2021 4:32 pm
Yep, burning toast triggers out Nest protect. You have to really cremate the toast to set it off, but does show it works....
Posted : 08/04/2021 4:36 pm
I'd at least have thought they could be set to only activate if both heat and smoke or heat only were detected rather than just smoke.
Posted : 08/04/2021 4:39 pm
The issue I see was actually that it's not a very sensitive smoke detector
I'd rather have one that goes off in parts of the house that shouldn't have smoke asap than ones I can burn toast under in the kitchen
The aico ones we have I couldn't even open the oven with the smoke detector we had in the dining room.(open plan but split level so a separate room for regs according to the local council)
Posted : 08/04/2021 4:50 pm
