Been a while since I’ve done the maths on this, so would appreciate any real-world experience!
I’m finally switching my Cotic to 1×11 (from 3×9) gearing. I’ll probably just keep the middle chainring to start, so 32T at the front, 11-46 rear, at least to start. Most of the parts are pretty cheap, which helps; but the cheap XT rear mechs are GS (medium cage) – which normally I fan of, but amn’t sure it’ll work.
The XT GS 11spd mech apparently has a capacity of 39T, and a max front difference of 10T; but max rear sprocket of 46T.
– Am I right that max front difference is redundant as it’s only a single chainring?
– 39T capacity should be good for 11-50 cassette in theory, but does the max sprocket size (46T) trump that?
– my gut feeling is that 32/46 should be fine at the low end, but will I be wanting 32/50, realistically? If I’ve done the maths right, I’ve lost 2 ratios off the bottom of my 3×9 setup
