Home Forums Bike Forum Full fast rebound (can it be sped up?)
Viewing 8 posts - 1 through 8 (of 8 total)
  • Full fast rebound (can it be sped up?)
  • rockthreegozy
    I run my Lyrik rebound fully open (fast). I’d like the option to go slightly faster, even if I just ended up back where I am setting wise. Can this be done easily by a tuner without compromising performance elsewhere? 2023 Charger 3 if it makes a difference..
    honourablegeorge
    Kramer
    Yes, they can use lighter damping oil.
    1
    rockthreegozy
    Not sure that kit does what I need but there is a €32 rebound shim kit I believe as part of the 3.1 rollout which might do the trick. Which I didn’t know about till you got me googling, so thanks that’s a start!
    bens
    Where are you with compression damping? If your running those wide open (or close to it) then as above, lighter oil is probably the easiest way.
    Simwit
    Does this help? (pages 107 & 108). It shows different shim stack arrangements for light, mid & heavy rebound tunes.
    https://www.sram.com/globalassets/document-hierarchy/service-manuals/rockshox/front-suspension/2023-zeb-lyrik-pike-service-manual.pdf
    rockthreegozy
    At the moment 0 or 1 click of HSC and maybe 3/4 LSC. So sounds like lighter oil might be the way, 3.1 parts appear to be September for UK stock..
    honourablegeorge
    rockthreegozyFree Member
    Thank kit makes your Charger 3 damper a Charger 3.1 – RockShox’s blurb is that it allows “68% more oil flow” –  and there’s a wider adjustment range as a result
