stuff-5 by John Clinch[/url], on Flickr
The suspension in my Fuel ex had a bit of play (2009 ex 6.5 so an early version of the frame with a long rocker and no floating brake thing). The play is coming from the pivots between the frame and rocker. The other pivots on the rocker are fine. The main swing arm pivot seems fine. The pivots at the rear wheel feel stiff but have no play
Given that the bike is old it doesn’t seem worth spending a lot of money so I’d just like do the minimum to get it up and running again. So presumably I can just post it some where and they’ll replace the two offending pivots? One pivots fell apart as I tried to get the bold out (this is in the picture) I assume that the remains can still be pressed out? I might need a new bolt as well as the Allen key distorted the hole getting the bolt out, Can I buy one of these bolts?
