New Yari. I’ve replaced the Charger with a Splug according to Novyparts’ instructions and switched the oil to 10wt but fork is otherwise untouched.
First ride was fine. Second ride there’s a rattle over rough ground from the right hand fork leg. Initially thought the Splug might have snapped or failed but pulled it this morning and it’s fine.
Fork appears to be functioning fine.
Before I pull it apart further, what might have come loose/broken that side and what might I need to do to remedy it? Is it only the rebound stuff that’s in there and how easy is that to replace/fix?
