Caveat: is it definitely this joint that is leaking? What’s behind the board? Could there be a leak on the pipework behind it which is trickling down the pipe somehow?
Assuming it is that joint, it’s a compression joint, so there’s an olive which is being compressed onto the pipe by the nut and which will weep slightly if not tight enough.
OR it will weep slightly if it’s too tight. The joys of compression fittings.
I’d try nipping it up slightly in the first instance: to do so you’ll need to constrain the isolation valve with a pair of grips, then slightly tighten the nut with a wrench. Dry the joint off with something, see if it leaks again.
