Home Forums Bike Forum First world Fox 38 forks dilemma
Viewing 11 posts - 1 through 11 (of 11 total)
  • First world Fox 38 forks dilemma
  • Mintyjim
    Perhaps dilemma is a little strong!
    I have a new ebike coming with 160mm Fox 38 Performance forks and the basic GRIP damper.
    I’ve never used a GRIP damper, having only used Rockshox for the last 10 years or so, purely by circumstance, not design.
    In my spares box I have a Smashpot coil conversion that I ran on my old Zeb’s. It was great.
    Do I:
    1. Leave the forks alone and just run them, after a lowers service.
    2. Spend £105 and get the bits required to install the smashpot on the Fox 38’s.
    3. Buy some Fox 38 Factory GRIP2 forks from Merlin for £725, then sell the new Fox 38 Performance forks off the new bike and the Smashpot and see a probably cost to change of about £150-170 to run the Factory spec forks.
      https://www.merlincycles.com/fox-38-float-factory-grip2-boost-mtb-forks-29-1-303650.html
    What would you do?
    My preferred riding is all the steep, natural/off piste stuff at Cwmcarn/Risca, Afan Masts, Brechfa and a the occasional Dyfi etc. I love steep, techy stuff and have no interest in fast, motorway, big jumps.
    chakaping
    I haven’t ridden a 38, but the basic Grip damper is great on my Z1 coil fork.
    So I’d do 1, followed by 2 if I felt I needed to.
    Edit: You can also sell me the Smashpot for my Zeb, if you wish.
    1
    kelvin
    You can get (and easily fit) the bleed “nipples” to the performance forks… I did with my 36.
    1
    leegee
    The bleed buttons don’t do much on my 38’s, you aren’t missing anything by not having them.
    Garter spring off and cable tie under the seal does the trick.
    1
    Mintyjim
    Damn it, why is no one telling me that option 3 is the wisest and bestest…
    Not fussed about the bleed buttons, it’s the damper I’m most concerned about. I don’t really want to use the forks and then decide it’s utter pants.
    Although chakaping’s feedback and my best google search indicates that the Marzocchi coil with GRIP is a great fork!
    bootsy
    No. 1 – Keep the 38’s. My mates experience with e-bike 36’s is that they are so much stiffer, the suspension works way better. He only added a TruTune carbon insert and is more than happy. His other forks are Grip2 36 with coil conversion but says he wouldn’t have bothered if they were as good as the e-bike 36’s. Granted Grip damper isn’t as tunable but chassis/suspension action is better.
    intheborders
    Buy a higher spec eBike that comes with better quality forks?
    acidchunks
    I ride factory 38s with the grip2.  They are awesome.
    If you can afford to make the swap, do it. :yes:
    muggomagic
    I have a ripmo with a set of DVO Onyx forks which I thought were the best forks I’ve ever ridden until I got an ebike with 38 performance forks and they are so good. Can’t help with which option you should choose, but they’re really good forks for a so called budget option.
    citizenlee
    Option 4. See how they ride and if you don’t like them upgrade the damper to GRIP2, then sell the Zeb Smashpot to @chakaping
    sofaboy73
    very much option 2 – stick the smashpot in their straight away. will the extra cost incldue the price of a new spring as assume you would need to change that for extra weight of bike?
    i’ve had both performance and factory 38’s on e-bikes and spent a lot of time tuning them and the smashpot feels better in every way and extra weight makes no difference on a e-bike
    if you do go for new 38’s, make sure you get the e-bike tuned ones (lighter damping tune). i’ve ridden both them and the normal ones and preferred the lighter tune – i always think fox forks are over damped – great if your really pushing hard, but normally have to run them near / full open on the high speed damping the rest of the time
