Home Forums Bike Forum Finally changing…
Viewing 7 posts - 1 through 7 (of 7 total)
  • Finally changing…
  • patriotpro
    The bearings on my Pitch this weekend but without specialist tools.
    Well i be right or is the task doomed from the start?
    tmb467
    Horst link (where chain stays and seat stays meet) is tricky if you can’t pull em out
    Angles on the stays make it difficult to put em back In straight
    The rest of them are pretty straightforward – if you don’t need to change the Horst ones don’t bother
    patriotpro
    Ah cheers for that.
    The set nearest the bb are the knackered ones so will leave the horst ones in that case.
    wolly
    let me know how you get on mine are about due too
    patriotpro
    You’ll have the report on your desk Monday 8)
    wolly
    Thank you kindly 😉
    tmb467
    When you’re reassembling shock pivot, stick a large Allen key thru to hold it together
    Check the manual to work out what washer goes where and build it up around the Allen key
    Then put bolt back in from the other side
    It’s a bit of a faff (I’d describe it more accurately but already been criticised for swearing this week)
The topic ‘Finally changing…’ is closed to new replies.
