Home › Forums › Bike Forum › Ebike musings – bosch vs shimano
- This topic has 63 replies, 33 voices, and was last updated 1 year ago by fatbikedog.
dangeourbrainFree Member
I’ve been hovering over the buy button for a few weeks and I think I’m finally going to give in but I’m stuck between two (well three if you include don’t buy either) choices.
Both are very similar, essentially the frame is the same bar paint. Travel on both is the same – though the shimano equipped one is on 36 factory vs 38 performance. Of the two I’m more inclined to the 36s for my riding but not enough to make it a clear winner.
Price is within £50 of one another so nothing to decide there.
The difference is one has an Shimano STEPS EP800 motor and much better finishing kit, the other has a Bosch Performance Line CX Cruise and a lower spec. Finishing kit would be enough to make the choice on a meat bike but is a bit less important on an ebike I think.
Battery on the bosch is about 10% bigger.
There’s the reliability thing but it’s amply covered elsewhere, the shimano bike is also half an hours drive away vs one and a half for the bosch so that much easier for warranty.
So what are the two motors like to live with? What’s the power delivery and battery usage like – it’s all well and good having more battery but if the motor is more hungry it doesn’t necessarily mean better life. The shimano is likely to be lighter too based on the smaller battery and better finishing kit so a marginal improvement in life from there.
Oh and is blue black faster than white and black?
dropoffFull MemberHeres our experience, we both ride identical bikes, shimano equipped with high spec finishing kit. Batteries are 630. Deb rides hers all day in trail and boost whereas in order to make my battery last I’m in super eco. The difference is I weigh 92kg and shes 55kg. Makes a huge difference to the performance.
dangeourbrainFree MemberBOsch for repair-ability 100%
Still not that repairable though and batteries are always going to be a big point of failure regardless of the motor.
Absolutely the shimano motor is “more disposable” than the bosch but you’re still relying on parts being available in 3 years time, plus the battery not giving out, plus being able to actually get it repaired by someone – all well and good you can get new boards etc but if you can’t get them installed that’s just decoration.
If (and it’s still an if) I buy either one it’s because I’ve accepted theres a significant limitation on lifespan in either case.
An ebike isn’t for life, it’s just for Christmas. (at least for a sealed system one)The difference is I weigh 92kg and shes 55kg. Makes a huge difference to the performance.
So what you’re saying is I should only ride it during the week to avoid beer related battery degradation?
2juliansFree Memberbosch over shimano every time – more reliable, more powerful, more efficient
dangeourbrainFree Membermore powerful
What’s the delivery like? Is it more of an assistant so increasing roughly in line with effort/cadence or is it more as soon as you turn the pedals you get the output of whatever mode you’re in?
SSSFree MemberCant speak for shimano (as i wouldnt have one in a lucky bag), but on Mrs SSS bosch ebike – if shes stopped and the bike is in Turbo, and she goes to start pedalling, it shoots off forward as if 100% power is applied instantaneously.
So she has to make sure its in eco when starting pedalling 😀
So assume power delivery pro rata power level is delivered instantlyAkersFull MemberIf (and it’s still an if) I buy either one it’s because I’ve accepted theres a significant limitation on lifespan in either case.
An E-bike isn’t for life, it’s just for Christmas. (at least for a sealed system one)This is my biggest concern with E-bikes, how long will they last (batteries being of particular concern) an what will they be worth after 3 years of use? Will anyone want to but a 2nd hand E-Bike that is 3 or more years old?
I tend to buy and use bikes for at least 5 years, replacing consumables as needed, before moving them on, and that happens rarely as a complete bike. Usually they are of the Trigger’s Broom variety, so as the frame reaches end-of life the parts will move to a new frame. E-bikes don’t appear to be sold as frame-only options.
dropoffFull MemberYeah sorry i was rambling a bit there. Point i was trying to make is that power and reliability are a little bit irrelevant if your battery isnt big enough to use it as it can be.
dangeourbrainFree MemberPoint i was trying to make is that power and reliability are a little bit irrelevant if your battery isnt big enough to use it as it can be
Sorry, I figured, you just worried me about the impact of full fat Friday on battery performance!
2SirHCFull MemberIn our riding group we’ve had less Bosch failures than shimanos, to the point all of the shimanos have failed atleast once. From memory we’ve had 6 or so of each.
tjagainFull MemberBosch power delivery can be tailored – and its proportional to effort put in
dangeourbrainFree MemberFrom memory we’ve had 6 or so of each.
Each brand in the group sorry or six of each failed?
2dangeourbrainFree MemberHmmm looks like a better question would be are there any upsides to shimano?
2oceanskipperFull MemberI think the Shimano will be quieter – right up to the point where it’s totally silent!
bear-ukFree MemberBeing a Bosch owner myself, but I have ridden a Shimano powered bike for a few hundred miles. The Bosch Gen 4 non smart has loads of grunt and will power you over all manor of obstacles compared to the Shimano. The Shimano loves to be in high cadence and is suited to the fitter riders. It also seems to get better milage than the Bosch.
Problem wise, with our group it’s only the Bosch owners that have needed new motors! My old Gen 2 is on its 6th motor, but my Gen 4 has just clocked up 4k miles without any trouble but others have had them go at 2k.
Bosch have always replaced them with no issues.
Batteries will outlast your bike so don’t worry about them. At least the Bosch ones do. I’m still using my old 2016 batteries in my gen 4 bike as they fit into the frame.
Problem is with anything you get good and bad so it’s always a gamble.
1HobNobFree MemberHaving had Shimano & Bosch powered bikes, there is no scenario where the Shimano option is better.
Less power, more unreliable, harder to fix, less economical & harder to sell.
oceanskipperFull MemberMy Bosch battery had taken about 100 charges when I sold it and still had the same range as when it was new.
oldfartFull MemberThe nearer your dealer the better 👍Bosch Gen 2 wasn’t really up to the job , after my 4th replacement Bosch suggested it was best not to ride it through water as they don’t like it 🙄Contrast with the Gen 4 my mates Whyte is 3 years old still on its original motor so issues sorted it seems .
I’m on an Orbea Rise with the detuned motor definitely likes a higher cadence.
juliansFree MemberWhat’s the delivery like? Is it more of an assistant so increasing roughly in line with effort/cadence or is it more as soon as you turn the pedals you get the output of whatever mode you’re in?
it varies depending on the mode you choose – from near instant power, to pretty gradual. I think the latest bosch system you can tailor the modes as well, but my bosch gen 4 (pre smart system) the modes are fixed to whatever bosch decided would be best, and they work pretty well, Tour+ and emtb are my goto modes usually – although I mostly ride my trek fuel exe ebike these days rather than the bosch powered bike
kayak23Full MemberBosch power on my Wild FS is instantaneous thereabouts, but the kick it gives is dependent on what mode you’re in.
Of course if you’re in turbo it’ll feel much more powerful as it first kicks in than if you’re in Eco.
I don’t have it higher than Tour, ever. Usually Eco until my legs start getting spent then Tour for the climbs and Eco on the flats and downs.
I wouldn’t have a Shimano I don’t think, though I would take their lovely minimal display over the awful Speak and Spell on the bars of the Boscheses.
big_scot_nannyFull MemberI would go with whomever is closest. You will very likely need the local dealer backup.
If you’ve never had an ebike before, then whichever you get will be amazing, the differences in power delivery etc are a bit moot.
Which geo fits you best?
olly2097Free MemberNo to a Shimano for me. Seen a few ep8 motors doe with low mileage.
One friend had his die at 260 miles for no apparent reason and had hardly ridden it so was out of warranty.
Can’t get parts for them either.
No to a giant ebike. Motor is locked down to giant despite being a Yamaha. Customised PCB. Which giant won’t sell.
Bosch, brose or Yamaha for me.
I’ve a Yamaha pwx3 on my bike and I feel it’s more powerful at the top end than a Bosch but that’s my opinion.
Shimano definitely feels weakest out of the 4 different manufacturers I’ve ridden.
doomanicFull MemberI’ve had Bosch Gen2 (4 failures in 2500 miles) and Gen 4 (1 failure at 2800 miles, while unused and unloved in the garage after I bought a Kenevo SL) and Mahle 1.1 (1 failure at pretty low mileage, same failure type now in evidence)
Wouldn’t own a Shimano. Used in isolation the Bullitt I borrowed was fantastic and easily the best handling FF I’ve ever ridden but when riding with mates on Levos it felt woefully underpowered and under-batteried, the 630Wh battery going flat at the same time as my mate’s 504Wh in his Levo.
1weeksyFull MemberFFS fellas… you’re not exactly inspiring me with confidence about getting this Orbea Rise off my mate.
1singlespeedstuFull MemberOut of all my eeb owning mates Shimano seem to be by far the least reliable and have the longest wait times on warranty work.
Two mates used to own Orange eebers that were that bad they bought two spare motors so they could swap them out and still keep riding while the broken motors went back under warranty.
imnotverygoodFull MemberAre all these failures due to off-road use? Wife has a 4 year old Bosch e-bike (sit up & beg hybrid) & so far it hasn’t missed a beat.
1TheArtistFormerlyKnownAsSTRFull MemberFFS fellas… you’re not exactly inspiring me with confidence about getting this Orbea Rise off my mate.
Have you been living under a rock? Virtually every ebike thread has a gripe about Shimano motors 😉
That said, a guy in our group has Shimano on his YT Decoy and it’s seemed relatively trouble free.
desperatebicycleFull MemberMy ‘dale has a Bosch and its stupidly powerful. And stupidly heavy. Next model down had a Shimano and a bit of research told me to go for the Bosch.
It’s been back for warranty once in the first 400 miles… creaking like a barsteward. Fixed by having all the mount bolts tightened. (told not to do this myself as they are tamper proof and it would void the warranty (arf!) )
weeksyFull MemberHave you been living under a rock? Virtually every ebike thread has a gripe about Shimano motors
It seems every ebike thread has gripes about most motors in honesty. Worst case scenario for me, i remove the forks and fit them to the Privateer, the wheels fit my Slayer, the shock fits the 141 or gets sold and the rest of the bits go in spares 🙂
Mine will be OK for warranty as i’ll get my mate to drop it in… but i expect by the time that runs out in 18 months there’ll be more places able to service/repair Eebs anyway.
CheesybeanZFull MemberFFS fellas… you’re not exactly inspiring me with confidence about getting this Orbea Rise off my mate.
Im sure your already aware the warranty is none transferable!!!!
1masterdabberFree MemberI’m currently debating going the emtb route and have been researching a bit… I’ve sort of decided going the Bosch route, definitely not Shimano.
The Brose seems a possibility but motor failures look very common. One thing I definitely want is a battery that can be easily removed for both transport and charging.
1juliansFree MemberAre all these failures due to off-road use? Wife has a 4 year old Bosch e-bike (sit up & beg hybrid) & so far it hasn’t missed a beat.
yeah, pretty much, there are commuter ebikes clocking up 10’s of thousands of miles on the same motor
juliansFree MemberI’m on my second bosch motor (bosch cx gen 4) , first died at 400 miles, second has done a further 500 or so,and is still going string but doesnt see much use these days.
I’m also on my second TQ hpr50 motor, first died at 400 miles, second still going strong at 500+ miles now.
Friend with an orbea rise (shimano ep8 motor)has now had 4 motors ,all done under warranty with a quick turnaround, in probably 1000+ miles.
weeksyFull MemberIm sure your already aware the warranty is none transferable!!!
That’s OK 🙂
1salad_dodgerFull MemberI got rid of my Orbea Rise as I couldn’t stand the noise of the Shimano motor rattling in the frame all the time. It was like riding a bike with a handful of chippings running free inside the frame.
masterdabberFree MemberMight be worth having browse round here (I have) https://www.emtbforums.com/
If I’m not allowed to post this then sorry, feel free to remove.
1dropoffFull MemberHave you considered a Specialized with the Brose motor, transferable warranty and very good dealer network.
