Viewing 4 posts - 1 through 4 (of 4 total)
  • Dual Air Reba O ring size?
  • silentsi
    Hi, does anybody know the size of the O rings on the positive and negative air springs in 06- Rock Shox Reba Races?
    I need to change mine as air is leaking between the two chambers and I don't want to spend £25 quid on a service kit when I just need two o rings.
    Thanks for your help.
    couldashouldawoulda
    The postive chamber has just one seal – the negative two. The kit comes with 2 "outside" of the pistons seals and 1 internal (between the piston and the shaft) for the negative chamber. You also get circlips and other bits.
    As accurate as I can get with steel rule(from a new set waiting to fit):
    o/s diameter – 27.5mm
    i/s diameter – 21.5
    Height 3.25mm
    Let us know if you manage to source them.
    silentsi
    I've found some here http://www.altecweb.com/home.asp?cat=Subcategory8320a
    they have some that measure 21.5 internal and 27.5 external but the cross section is only 3mm.
    Has anyone here managed to use non rock shox o rings successfully?
    bear-uk
    If they are made in the States, there is a good chance there imperial sizes.
    I just tried to replace some in my revs, and found them to be inbetween sizes from the boxfull of metric ones that I have.
    Do Lidl or Aldi sell O rings in boxes sometimes?
The topic ‘Dual Air Reba O ring size?’ is closed to new replies.
