You shouldn’t unplug anything without switching it off first to prevent arcing or incidental contact with live parts, that’s what the switch on the spur is for.
Arcing, maybe.
But the incidental contact is covered by a BS plug design. Hence nobody gets a warning to watch out when unplugging things, it’s not an issue any more.
But that’s still assuming the switch is remote from where it’s wired in.
I just love how on the same forum that everyone is convinced people will die if they use a dishwasher after bedtime with modern electrics you also have people advocating the use of something not designed for the task. It’s designed for lights, not a TV, funnily enough a lighting ring main has a smaller wire gauge than mains, why is that do you suppose?
