I’ve installed and uninstalled so many bits of software and I’m struggling
This setup is for a live band, with 4x RGB strip (tubes), we will potentially add more
The idea is that we have some on stage lighting that does simple stuff (colour change, basic effects with the music)
I had them working on a trial of EMU but the effects were a bit too subtle – there was no ‘off’ between transitions but just a fade
It also only worked as a predefined prog, not audio reactive
Looking at getting licensing but want to make sure it’s worth it and that I can use it!
I want dmx software that does the following:
Must work with Enttec DMX Pro
– Song list (programs) that I can define which fixtures are used
– For each fixture (generic RGB) I want to define which colour(s) to be used
– For each fixture & colour, I want to set the effect (could be flashing/wave or colour change)
– For each of the above I want to be able to apply additional scenes e.g. chasers across defined fixtures
– Ideally the effect(s) can be triggered by audio (live) and have the option of predetermined
– These must be able to be preset and saved as a set and then cues by external device (foot pedal)
To set this up, it needs to be simple and intuitive and stable and not need a degree in lighting design – I’ve tried many and none meet the criteria
I just want to select the song, pick the lights, set the colours, select the effect, save and go…
Suggestions please!
Thanks
