Home Forums Chat Forum Cutting a plywood sheet?
Viewing 40 posts - 1 through 40 (of 63 total)
  • Cutting a plywood sheet?
  • gobuchul
    None of the builders merchants or DIY stores near me, offer a wood cutting service.
    I would like to cut a 5.5mm plywood 2400 x 1200mm sheet in half, to make to square pieces.
    What is the best way to make a neat, straight cut?
    I was thinking using a Dremel with a 38mm cutting disc? Would it make a neat cut or cause a load of splinters and cracking?
    1
    pk13
    Some one near must have a track saw you can borrow for 10mins
    1
    willard
    Yeah, one of those. I used a jigsaw with the only blade that I could find to do a load and the thinness of the ply and the curves made it a terrible cutting experience.
    1
    droplinked
    1. Track saw
    2. Circular saw
    3. Hand saw or jig saw – using a clamped piece of stud timber as a guide
    1
    burko73
    Have you not got a b&q nearby?
    bruneep
    Wouldn’t be my 1st choice but is the a B&Q near you that offers a cutting  service or do you need the sheet delivered as well?
    scc999
    Tracksaw.
    Where are you based? Someone close to you may have one and be willing to help
    gobuchul
    The nearest B&Q is an hour away.
    We have a builders merchant but they don’t do the cutting.
    I’ll try and find a tame joiner who can do it for me.
    1
    thisisnotaspoon
    Bear in mind Plywood is typically 2440×1220, so you’ll need to do more than 1 cut if you want 1.2m squares.
    As long as you can get it home in one piece, cutting it with a hand saw really doesn’t take that long, probably quicker than messing about driving somewhere.  Just clamp the sheet with a few pieces of 2×4 wood or box/angle section or similar to use as a cutting guide if you want it really straight and to keep it from flexing too much.
    kormoran
    Hand saw and clamped or even screwed cls/timber baton
    burko73
    I’d mess it up with a handsaw. Track saw pretty much guarantees straight accurate cuts if you measure properly. You may even be able to buy the timber online pre cut at the size you want it?
    5
    martinhutch
    I use a small cordless circular saw with a straight edge clamped on as a guide.
    3
    Ewan
    I can’t think of a worse tool to do this with than a dremmel! Tracksaw is the correct option, but if all else fails two 2x4s clamped to the board to act as a cutting guide + a decent hand saw.
    5
    DaveyBoyWonder
    Chewing through it would be preferable to a dremmel for a job like that.
    1
    tthew
    A Demel! FML, you’d be better going through a 5mm sheet with a couple of cuts with a decent Stanley knife.
    duncancallum
    Could use a router and a fence.  Especially if you want it bevelled.
    But track saw for fast accurate cuts
    thegeneralist
    Handsaw would be fine. And give a much better job than a jigsaw if you’re cack handed
    benpinnick
    You must know someone likely to own a circular saw if not a track saw. That + a straight edge (long spirit level, nice piece of timber) + 2 clamps will do the job in 10 seconds.
    2
    mrmonkfinger
    Reading between the lines, I think a tame joiner might be the best option, no offence intended.
    1
    DT78
    If you think a dremel is a sensible idea you might want to get someone to help!
    If you do borrow a track / circular / jig watch some safety vids on youtube about how to keep all your fingers
    The best answer is a track saw, though if you clamp a straight edge you can do it with a variety of tools.
    So to do it well as well as the cutting tool you will need clamps and saw horses of a decent enough size to take a full sheet.  I use 3 or 4 horses on long cuts as you want both sides fully supported as you cut
    1
    Northwind
    Do not under any circumstances attempt it with a dremel!
    Handsaw is way easier, trust me, even if you think you’d mess it up it’ll still be better than messing it up with power, with 100000 tiny cuts. Just take your time, and cut fairly shallow so that the length of the saw tends to keep you straight, and try not to cut your leg off.
    Tracksaw would make it super easy and yep see if you can find one that has one, everyone on STW has one parked beside their woodburner. Just the ideal tool for the job.
    sockpuppet
    Asssuming that B&Q offer a cutting service, then spend the hour driving there!
    Unless you have a neighbour who’ll help, arranging a joiner will take more money and more time!
    A sharp panel saw will do an amazing job if you know what you’re doing – I suggest buying one for any given capable neighbour who’ll help and giving it to them when they’ve made the cut!
    kayak23
    Don’t use a track saw without a decent cutting table for support.
    SCM make decent panel saws and have a lot of capacity with large sliding tables and a digital display.
    More than enough for cross-cutting an 8×4.
    Get one of them I’d say.
    Use the scribing blade though and you’ll get a cleaner cut across the grain 👍
    fooman
    Try another merchant (others will cut) or drive to B&Q it’ll probably be quicker than getting tools together to do it yourself.
    100psi
    5.5mm ply can be cut easily with a good sharp Stanley knife and a straight edge. Just keep our left hand out the way! 3 or 4 passes with a sharp blade should be all that’s needed.
    finishthat
    A Rotozip spiral saw would do it – Dremel on steroids – cheap used full kits still around as lots were sold to folks who never used them – bit of a niche but I used mine for a few jobs , bit of a niche really but for about £20 very capable .
    hardest thing is getting a big floppy sheet into a good place to chop it up
    ElShalimo
    There’s must be somewhere in Berwick that can do it?
    Ambrose
    kayak ftw! 🙂
    Northwind
    kayak23
    Why not? Just chuck some random bits of offcut or wood (nail free!) or whatever under it and set the depth to be just thicker than the board. I mostly just use mine on the ground
    batfink
    Assuming you don’t want to make a large investment in tools, and the Dremel is a horrible idea, I would say your options are:
    1. Drive to the nearest place that will cut it for you
    2.  Cut it with a hand saw.
    Personally I’d go for option 2, even if It meant buying a new handsaw to do so (although I wouldn’t in reality, because obvs I have a tracksaw).
    You haven’t said what this is for – but you might want to consider how square the squares need to be, and adjust your cut/cuts appropriately, don’t assume the the board is starting with perfect 90 degree corners
    Wally
    5.5mm will be like butter to a new handsaw. Each stroke about 20cm of cut.
    Put away the Dremel or nail clippers. Quality handsaw – BAHCO 9TPI WOOD HARD-POINT SAW 22″ ?
    oldnick
    I use two big bits of 2″ thick stiff packing foam on the ground to support 8×4’s when tracksawing. Easier to cart around than a pile of proper trestles.
    kayak23
    Why not?
    Because I was being silly.
    You saw the 40-50k industrial panel saw right? 😉
    sirromj
    I can say from experience that trying to cut a 2440×1220 sheet on pallets on an uneven surface with a  circular saw is less than satisfactory. I especially enjoy trying to find something I can clamp as a guide that will fit under the motor. Also love having to move the clamps every five seconds because they get in the way of the motor.
    tomparkin
    The best approach in my experience is cutting with a new handsaw in B and W carpark with the timber half wedged in the boot after you’ve realised there’s no way in hell an 8 by 4 sheet is going in your car.
    Fun and jokes aside, if you’re going to put it on a roof rack I would have a couple of lengths of reasonably stout CLS or similar to support it with. 5.5mm will flex a lot and maybe even snap if the way home is windy or populated with HGVs going in the other direction*.
    As to actual cutting, just use a handsaw.
    *or both. Ask me how I know.
    thegeneralist
    Impressed by Tom outing himself as even more useless than the OP. That takes some doing !
    gobuchul
    I have no shame in being useless!
    I have nowhere suitable to secure the sheet even if I did have a handsaw and wasn’t completely cack handed when it comes to anything wooden,
    I didn’t know woodworking carried such a badge of honour?
    1
    DT78
    no badges of honour!
    just those with fingers and those with ones missing 🙂
    have one friend with one finger missing the last knuckle and above due to a circular saw mistake – bascially just running it over his own hand…..
    For what its worth I can do lots of stuff with wood but for what ever reason I am truely crap with a standard hand saw.  I use jap pull saws (if I have to) for anything precision and power tools for everything else.
    thegeneralist
    I’m just smug because I own a handsaw and have used it. Anything beyond that and I am utterly useless. Just enjoying my one solitary day in the Can camp.
    Soz for any offence
