I find mashing a load of grease in works about 50% of the time for creaks. Trouble is the grease finds the path of least resistance and oozes out one bearing rather than filling the whole thing and greasing all four.
Good news is that I’ve found that removing all the suspension bolts and re-applying loctite/grease and re-touquing using the directions/numbers as per this page has always fixed any creaks that grease-gunning hasn’t.
https://www.santacruzbicycles.com/en-GB/bike/hightower/1
You need to make sure you are checking the actual bolts not just the visible ones that just tighten up the wedges.
Note that at some point (MY18 I think), suspension bearings were switched from radial to angular contact and touque numbers are very different between the two (both are shown on that page).
