I’ve never used it. Can’t see that it would do anything to benefit you either. It’d just add weight. Once you’ve got the seal, air pressure is holding everything where it needs to be anyway (crucially the beads of the tyres up against the bead hooks on the rim) so I just can’t see a point.
I’ve done many many Ghetto conversions now, and aside from the initial faff, I’ve got to say its probably my prefferred method of running tubeless. It’s one of those “why didn’t I think of that” bodges that actually just works (tyre choice dependent). Just find a cheap supply of inner tubes (or don’t change your tyres til they wear out) and you’re laughing!
