Home Forums Bike Forum Coil shock for Transition patrol
Viewing 10 posts - 1 through 10 (of 10 total)
  • Coil shock for Transition patrol
  • rhid
    This has probably been discussed at length but does anyone run a coil shock on a patrol? If so what are you running?
    I believe the cane creek il double barrel on is popular but what else do you run?
    escrs
    DVO coil shocks are meant to be quite good on the Patrol
    Transition’s UK distro also distribute DVO suspension and their staff seem to like running the DVO coil shock on their own Patrol’s going by their Facebook page
    poah
    any coil from rockshox, DVO, fox, CC etc will do but just watch for the weight as the patrol mk1 and 3 have fairly linear leverage ratios.
    tuomoe
    I had an old Fox DHX4 that I got really cheap. Worked liked a charm and was a significant improvement not only in terms of tracking but poppiness as well. Loved it to bits but bike got stolen 🙁
    marksnook
    it’s weird that transition say the patrol is too linear for a coil and designed for air but all the builds I see are running coil including most of their own bikes. You reckon someone just messed up and ordered too many air shocks so they are telling people to stick with them?!!
    The mrp hazzard coil comes in the right size I think. It has a progressive spring option too which sounds like it could be good
    pickle
    What size is it? I’ve an RS vivid coil which is pretty much brand new. Size is 216×63
    poah
    I run a coil on my suppressor – Their advice to me was the same above.
    rhid
    Pickle- it’s 216 x 63. Drop me a message to discuss.
    SOAP
    I’ve had a pushed Van RC a DHX2 and now got a ohlins TTX
    VAN RC was the best as tuned for the bike by TF.
    DHX2 was to much faff
    (I like to fit and forget and not use lockouts)
    TTX tuned by JTech is very good.
    Coil on a patrol makes it a rock killing monster of a bike 🤘🏻
    jamj1974
    I feel a more progressive tune works best on my Patrol – I use a number of volume-reducing o-rings in my air shock.
    So, I would go for a progressive tune myself – think that would be best.
The topic ‘Coil shock for Transition patrol’ is closed to new replies.
