Almost anything can be the cause of a once-per-crank-rotation click because the forces from your body go through the whole bike with the same frequency.
Cleats, pedal bearings, crank bolts, chainring bolts, bent tooth, stiff chain link, BB bearings, BB cups, seat clamp, saddle clamp, cracked frame, stem bolts, headset, you name it. (You don’t mention kit: derailleur or singlespeed? dropper or standard post? 1x or front derailleur? cleats or flats? full sus, hardtail or rigid?)
Try things like riding no-handed, pedalling backwards, switching body weight between pedals without moving the cranks, turning the cranks on the workstand, grabbing the crank and checking for play, and so on.
If nothing presents itself, try the easy stuff first; then try the stuff which you can swap with items from the spares box; then try cleaning and regreasing threaded components.
