Something smoky, preferably chipotle but a bit of paprika can work. Always ground cumin but that should be a given. A teeny amount of cinnamon and a couple of cloves gives a subtle background note. And a pinch of MSG always helps.
We stopped using meat and replaced it with lentils when some veggie friends came to stay. We much preferred it, and now use lentils all the time! Out of choice!
This is a helpful site, explains the different chilis. I go with a mix of a few different ones, New Mexico, Ancho, Chipotle, toast them lightly first, then blend, usually with a few sun-dried toms too. I also use Ox cheek in there as it’s nice any tasty when slow cooking
Best quality mince you can get your hands on and really, really brown it. Not to the point of burning, obvs, but you want it really caramelised. It’ll rehydrate as it slow cooks in the sauce and give you great texture and depth of flavour. Echo the sentiments on dark chocolate above (go 80% cocoa or more). Only other suggestion would be some good quality home-made stock (unless you can get a shop-bought one without all the salt that’s usually added).
Have heard of others using cuts like shin of beef or brisket instead of mince. These would do a lot of the work of the aforementioned stock I’d guess.
Yeah, mince is the least-best meat to cook it with, TBH. You really want a tough old stewing cut, like brisket, shin etc, and cook it in a slow cooker.
I’m an absolute carnivore, but if you can’t get a decent bit of stewing steak and let it just fall apart, then kidney beans, white beans, brown beans, and quinoa. Smoked paprika, cumin, oregano, beef stock, and chipotle to taste as well. Slow cook for as long as you can stand it, but at least four hours.
I also follow the serious eats recipe linked above (I have Kenji’s book with it in). It’s immense. I find even just following his instructions to make chilli paste (freeze in ice cube trays) and then using them in a generic chilli instead of spices makes a difference.
get the Hot smoked paprika for some zing. Let it gently bubble on the hob for a day, or in the oven, to allow the flavours to develop and gain some proper depth
I make a really strong birria sauce from ancho and guajillo chillies, onion, garlic, sun-dried tomatoes, grilled bell peppers, spice mix (usually cinnamon, cloves and coriander), cider vinegar, honey and the water I rehydrated the chillies in, then add it to a standard beef chilli to taste. The birria lasts a week or so in the fridge and it’s also good underneath the cheese bit of cheese on toast.
A good splash of red wine when browning the beef and some tomato purée for richness. Some dark chocolate right at the end to finish. I put mushrooms in mine as well.
I slow cook a shoulder of pork all day in BBQ sauce then ‘pull’ it. I then fry off onions with lots of garlic then add the pork with a sachet of Old El Paso Chilli mix plus lots of chilli powder, turmeric, smoked paprika, lemon juice, Worcester Sauce then add the tinned tomatoes, and eventually kidney beans (with chilli sauce as mentioned above) and a load of sweetcorn. I usually end up adding a splash of whatever chilli sauce I have in the cupboard and other odds and ends. My wife likes hers quite spicy but I like mine hotter so I then add a couple of drops of ‘Dave’s Insanity Sauce’ to mine.
I occasionally do it with mince (I just fry the raw mince with the onions and skip the slow cook phase).
If an individual’s opinion is that chilli is just spicy Bolognaise, their opinion can be quickly discounted and don’t accept any invitations to dinner at their’s.
Ground cumin and ground coriander we also go heavy-ish on bay, oregano and basil and a well heaped teaspoon of cocoa powder. Authentic, almost certainly not, rich and spicy yes.
Plenty of mild chilli powder is better than a small amount of hot in my experience. It just seems to spread the flavour.
Chipotle or habanero sauce also good as a depth/heat additive. We used to have a fairly ridiculous chocolate habanero sauce and just a half teaspoon added to a normal mix added a welcome depth and kick.
My recipe. Note this is an intentionally mild base, I add actual chillies and/or pain to taste depending on target audience. I’ve no idea about meat, I chuck a pack of Quorn mince in 15 minutes before the end. I’ll typically double up the quantities here and freeze half of it in individual portions.
