Home Forums Bike Forum Change travel on coil Suntour Zeron fork?
Viewing 12 posts - 1 through 12 (of 12 total)
  • Change travel on coil Suntour Zeron fork?
  • cjr61
    Afternoon,
    I picked up a 150mm travel spring for my forks and swapped them over today.  Unfortunately it’s still 140mm travel…hhhmm. I didn’t take the lowers off as assumed it was just taking the top cap off and swapping. Can anyone enlighten me please? Thanks
    Chris
    dc1988
    You’ll likely need to pull them apart. There might be a spacer or a roll pin that needs moving.
    cjr61
    Thanks, found an exploded diagram so reckon you’re right. Seems to be spacers denoting 130/140mm. I’ll pop those off and hopefully sorted.
    Screenshot 2024-05-01 at 18.33.05
    dyna-ti
    Any idea what size thread 3e is.
    Ive similar(different fork) and thought the fender mount size was an m5 but it isnt and i havent got any m4 to check.
    Just if you know 🙂
    cjr61
    Hi @dyna-ti,
    Just measured my bolt and it’s 8mm long thread and 4.8mm width. Assume that’s an M4 8mm you’re after.
    P.s. in case anyone was losing sleep, I removed the spacer and hey presto 150mm travel!
    Chris
    pushup
    Such a great fork. Has so much traction over rough terrain. I took mine to Dyfi and was really impressed with it on my trail bike.
    beanbert86
    Hi mate, I have the same fork on my GT Zaskar currently at 130mm but I wanna go up to either 140mm or even 150mm. Which spacer on the diagram did you need to take out? Cheers
    bens
    At a guess,
    6E to make it 140
    6E and 6D to make it 150
    Not sure if you’d need a longer spring?
    beanbert86
    Cheers, yeah you can buy a 140mm or 150mm spring for it so I was gonna do that but not sure how much fitting was involved!
    cjr61
    As bens said really. Fairly straight forward if I remember correctly. Drop the lowers, remove spring. Remove spacer and replace new spring. Fresh oil and should be good to go.
    beanbert86
    Nice one cheers fella. How’s it ride with the bigger spring in, you happy with it?
    cjr61
    Rides really well. It’s a simple and chunky fork but find it nice and plush and pretty bombproof. I’m not a good enough rider to worry too much about damper tech
