Change chainring wi...
[Closed] Change chainring without removing crank?
4 Users
Slightly lazy, but would I be able to replace an AB 32t oval on a M8000 crank like for like without removing the crank?
Thanks
Posted : 16/06/2021 5:21 pm
Well I can change a 100bcd ring that way so don't see how 3mm would make a difference.
Posted : 16/06/2021 5:30 pm
But the best thing about Shimano cranks is how easy they are to fit & remove.
Posted : 16/06/2021 5:39 pm
Yes I've done it. Replaced with an AB 30t oval.
I'm assuming the 8000 series are XT cranks?
Posted : 16/06/2021 5:40 pm
Thanks all, it looks like I can.
Yep, m8000 is XT. And yes I know HT2 cranks are really easy to remove and refit. But ad I said it’s a bit lazy đŸ™‚
Posted : 16/06/2021 5:45 pm
Just coming back to this to confirm that you can.
Posted : 22/06/2021 1:02 pm
