Those record hubs are superb because they were fully serviceable. The races can be pulled and replaced. Plus they are through hardened not just case hardened like all other hubs so last for ages.
Those look like 100 front and 126 or 130 wide (possible as they are post 1978 versions) rear. Also for Italian threaded freewheel but an English should fit fine but worth checking.
If searching for a frame, worth noting that 126mm drop outs are most common but 110, 115, 120, 122 and 126 versions exist. Hubs can be adjusted to fit using 10mm washers but may need a new axle depending on difference which are hard to find.
If you are building up a period bike, might want to consider buying a complete bike that just needs a few bits swapped as the parts on their own seem to go for silly money these days
Retrobike is your friend for this but email in profile if needs
EDIT modern track frames are 120 but older ones were 115 or even 110 (with a 90mm front)
