Home Forums Bike Forum Cable Ties on frames – who smooths theirs after cutting?
Viewing 40 posts - 1 through 40 (of 46 total)
  • Cable Ties on frames – who smooths theirs after cutting?
  • bonesetter
    So who does?
    And with what?
    scruff9252
    I use nail clippers. The slightly rounded cut takes most of the sharpness away.
    singlespeedstu
    Just cut them level to the lock with a Stanley knife.
    aracer
    The end? I just cut level with the edge of the fastener so there’s no end exposed to worry about.
    whitestone
    +1 to cutting them flush with the fastener
    Teetosugars
    Yup, nail clippers are your friend.
    joshvegas
    I leave the ones on my stays long.
    Brrrr
    Cut then hit them with a lighter smooth and not stabby
    bonesetter
    I file mine – especially after tonight:
    One opened up my leg like up a surgoen’s scalpal – blood all over the trail
    Quite upset a couple walking by
    ThePinkster
    Nice sharp pair of wire cutters and get as close to the fastener as possible.
    Not thought of nail clippers before though, might try them next time.
    singlespeedstu
    If you cut them flush there’s nowt left to damage you.
    LoCo
    Mini cutters and smooth with needle file if really have to use them.
    bonesetter
    The wire cutters don’t get close enough
    downhilldave
    Nail clippers here too,nothing sharp left to bite you when cleaning.
    singlespeedstu
    Use a Stanley knife then…
    Try not to cut yourself with it though. 😆
    Onzadog
    Stanley knife flush to the block but also think about where the block is sitting to minimise the risk. For example, on stays, I’ll thread them through so I can tuck the block inside the stay.
    Thrustyjust
    Stanley blade here too. Mind the cables and hoses when it cuts through !!
    mattsccm
    🙄 Does your mum still dress you? You do cut the surplus off don’t you?
    Just use the same side cutters to cut it flush. 1 snip and its done.
    NorthCountryBoy
    You should cut cable ties with “flush cut” pliers” I have decent pliers for work from snap on and beta but bought a cheap pair at the market for £2 there fine.
    Less than 3 quid on eBay save yourself gouged legs!
    http://pages.ebay.com/link/?nav=item.view&alt=web&id=131549134176&globalID=EBAY-GB
    spectabilis
    I use a knife and just knick them flush to the fastener then twist. They tear off nice and smooth with less chance of cutting through into hoses, paint, fingers etc.
    momo
    Stanley knife here, one of my mates is really pedantic about these things and it rubbed off on me years ago.
    davosaurusrex
    Side cutters and a needle file. I love a bit of OCD cable tie filing
    Three_Fish
    I use a small piece of 5mm tubing to hold onto cables/hoses. Much neater and more secure. Excess cable tie cut flush with a sharp blade.
    scotroutes
    I use a small washer the same way. Less of a gap between cable and frame/forks too.
    MrOvershoot
    Anyone who says “side cutters” will be taken out and shot.
    Having worked with industrial electrical installations for 30+ years that have 10’s of thousands cable ties on everything I have had & seen enough slash wounds from cable ties cut with side cutters to know you are doing it wrong.
    Cut flush with a Stanley type knife & file smooth if your still not sure.
    antigee
    possibly a bit ott but sidecutters AND smooth off with hot soldering iron 8)
    emanuel
    I thought this thread was pointless, but the tube idea is really good, so I learned something today.
    I use some japanese bonsai scissors.they get right inside. not had a problem, but I tend to use the smallest cable ties I can find.
    my 2p.
    BigDummy
    I love how this thread has developed into “show me your obscure tool for a simple task”.
    I borrow my wife’s girlfriend’s Korean-style bikini-line-straggler-trimming-blowtorch, personally. 🙂
    gofasterstripes
    Simply focus your powers on the sharp end.
    Failing that, a lighter.
    cr500dom
    Flush cutters, they are designed for just this job.
    Mine are snap on, and I`ve had them for years only for cutting cable ties.
    My old boss used the first pair once for cutting lockwire and wrecked them.
    He got a bit of a shock when I brought another pair and gave him the bill along with the now wrecked ones.
    But cheaper versions are available.
    They cut completely flush
    bigyinn
    I tend to leave 15mm proud of the block so that I can remove and re-use them as I see fit.
    So I’ll normally mount them in such a way that the ends are impossible to catch yourself on and I’ll take the corners off the cut edge, so no sharp bits.
    reluctantwrinkly
    What you need is a pair of flush-cutting wire cutters that are used for trimming components on circuit boards. These have a flat ground surface and the blade edges are ground from the inside like a one-sided knife edge. Clean flush cut with no nasty sharp edges. RS stock them, they are only lightweight but perfect for the job. Edit–Oops, beaten to it!
    thisisnotaspoon
    Threefish +1
    Although when I’m feeling lazy it usually ends up being a zip tie inside a zip tie rather than a bit of pipe.
    Holds cables far enough away form the pain that they don’t scratch either. And rotate the ends so they’re not pointing at your fleshy bits.
    stumpy01
    I trim them with flush side cutters.
    Then smooth the cut end down with 400, 800 and finally 1000 grit wet & dry before buffing the end with a polishing mop on a dremel.
    It’s the only way to be sure you aren’t going to injure yourself.
    hatter
    End cutters for the win, perfect every time, much less hairy than using a Stanley blade.
    Gary_M
    Sharp stanley blade and if there’s any roughness I’ll file it smooth.
    thisisnotaspoon
    Next off you guys will be telling me you use a guide to cut the steerer and file the burrs off afterwards……………
    gofasterstripes
    No, simply use a spoon handle as a deburrer 😉
    bonesetter
    emanuel – Member
    It started out as a piss take, but I think it has taken on a deeper meaning now 🙂
    pirahna
    You can also twist the ends off.
    surroundedbyhills
    2 pages and a uchoob vid – wow!
The topic ‘Cable Ties on frames – who smooths theirs after cutting?’ is closed to new replies.
