Also- why doesn’t the above kit work with non Evo Hope hubs? I thought the only difference with Evo was a 40t ratchet?
The rear evo has a larger axle sleeve, 17mm I think, over the standard Pro2. Note also there are 2 Pro2 Evo versions, the Pro2 Evo and the Pro2 Evo40T which came later. Interestingly the hub shell never really changed its dimensions, as hope just fitted a Pro2 EVO40t shell with the innards of my standard Pro2.
The fronts are the same across all Pro2, evo or not.
Pro4 looks good, disappointed they went with equal size flanges though, so you still need different length spokes on each side, opportunity missed.
