I know nothing about clipless pedals, but I have a new job starting soon and will be commuting ~10 miles each way (Half on half off road, probably on a grrrravel bike) and I'm thinking about getting some proper cycling shoes and pedals instead of using flats. If I like it I might even stick them on my mountain bike. Maybe.
What do I need to know? Is it just a case of buying the cheapest shoes and pedals and seeing how I get on or is buying cheap stuff a bad idea? (Given that cheap flats are terrible...)
By value do you mean cheapest???
Shoes that fit.
If you are getting pedals without platforms (they are fine) then a stiffer shoe
Cheapest is a shimano pedal, personally don't like them but lots do.
Specialized do some basic nice shoes like this
http://www.specialized.com/au/en-au/ftr/shoes/mtb-shoes/sport-mtb
Work at it in a field first 🙂
Shimano SPD pedals are ace from entry level to top of the range, i'd suggest go cheap SPD.
Could you borrow some? If you're Halifax/Huddersfield way I'm happy to lend you some SPD pedals.
Like a lot of things, I'd go Shimano for both pedals and shoes. Both will last forever and are cheap as chips.
Oh.... And you will keel over sideways at a set of traffic lights. Consider it a right of passage 😉
M520 Shimano's and the on one Agu Torquay shoes. No need to spend more.
Kind of, but with drivetrain bits I know that deore/SLX are a bit of a sweet spot for value and anything above that is lighter and a bit more bling but perhaps without performance improvements that I'd notice. I suspect there is a similar pattern for pedals...
Part of the reason I've found a mostly off road commute is to reduce the likelihood of this.
You're right that tgeres no need to go XT, [url= http://www.chainreactioncycles.com/mobile/shimano-m530-spd-trail-clipless-mtb-pedals/rp-prod67249 ]these things[/url] are excellent!!
When you fit your pedals, back the tensioner screws on them right off, to give yourself a fighting chance
So many shoes out there... I get the feeling this is not to be done online. I'll head to the bike shop in a bit and see what they have got to try on.
Does this control how tight the cleat is held on to the pedal?
There is no point fighting it, it will happen no matter what and I just need to accept it and move on (Sheepishly and with a grazed elbow).
Becomes second nature in no time at all. Just give barbed wire a wide birth on your first ride. Don't ask me how i know 😳
I've put 7k miles on a pair of £15 M520s and they still function perfectly. Shimano shoes can be a bit on the heavy side but I've found they last ages.
M520s just run forever and are cheap as chips
Wiggle dhb shoes are worth a look for starters or shimano
to clarify my dislike of shimano is that the CB's are much easier to get into and very predictable to get out of.
Forward, Backward and push down clip in.
As above the cheap pedals are grand.
As for shoes I wouldn't buy cheap, and I wouldn't buy unseen either. Too easy to get a crap flexy shoe that doenst fit.
