well, it depends.
stans are wider for the same weight as the equivalent mavic, and the cool cats will tell you the Mavic haven’t progressed, and their rims are the same profile, and they’re too narrow, blah blah blah…
Wheel strength is pretty much down to spoke tension, and all things being equal you’re as likely to ding your stans rim as you are the 719 rim you just bust, so in reality, as long as the build is OK, for most riding it doesn’t really matter.
upsides to stans: bit lighter, better profile
downsides to stans: no eyelets, it bothers some people, others not so much (make sure spoke tension is within limits and you’re probably going to be OK)
upsides to Mavic: tried and tested
downsides: probably a bit narrow
In the true tradition of STW: Pick a side and be a dick about it. 😆
