Hi all,
Please help a DIY noob. I’m capable of doing stuff but only once I know what I should be doing 🙂
I have a 2m x3m section of garage where I’d like to wall mount bikes. The wall is plasterboard and the studs aren’t in useful places. I’ve no idea what is behind and don’t really want to pulling the wall off. This section is in the far corner so it doesn’t matter too much what the final finish is.
Can I just put up a 2m x 3m bit of 18mm ply or OSB direct on the plasterboard, with some rawl plugs through the board?
Plan the would be to put the bike mounts on smaller rectangle of 18mm thick OSB or ply wood and mount to the new wood lined wall (i.e. have two layers of wood between the plasterboard and metal bike mount, for some extra support of the mount and ease of repositioning).
Or is there a better way to do it? Should I use batons on the plasterboard then ply/ OSB on top or doesn’t it really matter?
Thanks!
