Home Forums Bike Forum Are there any silver riser bars with 9 degrees backsweep
Viewing 11 posts - 1 through 11 (of 11 total)
  • Are there any silver riser bars with 9 degrees backsweep
  • noeffsgiven
    Cant seem to find any so guessing they don’t exist, Title comes close but only 8° backsweep,ideally want 38mm rise in 31.8, Gusset and Reverse are also not quite right, Leatt have some in the pipeline but only 35mm version it seems.
    monkeyboyjc
    The leatt ones will only come as a package with their stems iirc.
    I’ve recently bought a Ritchey 10d trail riser bar – not available in silver unfortunately (although the flat version is).
    noeffsgiven
    Thanks for the replies but I’m probably chasing a non existent product, Ritchey ones are too low and too heavy, Spank are close but also a bit too close to 400g for my liking, the Title ones would be great if they had one more degree backsweep, I love the look of them but they’re ruddy pricey, I guess they just aren’t out there around the 300g mark. The leatt ones will only come as a package with grips for some weird reason, also pricey and probably not in 31.8 version. Whoever made Nukeproof horizon and Ragley’s bars might do them raw.
    Stevet1
    Pro taper make their bars in black or silver but they are 8 degree backsweep. Great bars though.
    trisysjoint
    Gusset do these.
    https://www.ison-distribution.com/english/product.php?part=HBGUS252S
    8 degree only but it’s close and they’re silver….
    Stevelol
    Don’t Ergon do some grips that are tapered to simulate more back sweep? May be an idea to give you more options.
    mattrockwell
    Yep, Ergon GE1 grips add a little. Dunno if it’s the solution here though, as I can’t feel the difference between 8 and 9 degrees back sweep.
    jfab
    Non silver bars the right size/shape and some oven cleaner?
    Title, but they’re 8°. 9 seems elusive in silver.
