I remember a few years ago the Fox 15mm QR was much slagged by the STW intelligensia for being inferior to the RS 20mm maxle. Main complaint was a lack of lateral stiffness, and a pointless new standard. Seemed to make sense 20mm is always going to stiffner (but may not be perceptibly stiffer) than 15mm. The power of Fox/Shimano was always going to drive the market.
Now for 2012, RS are producing both 15mm and 20mm Revelation forks, but only importing 15mm forks into the UK. Why is the case if 20mm is better? Why upgrade to the new fork when the older is better? The Revelation is probably the benchmark trail fork, along with Fox Floats by which others are judged.
Is it a hub compatibility issue, and hence driven by the market demand? Hope Pro2 convert very easily to 20mm, but maybe the others, Mavic etc, are not so straightforward.
There is the Pro2 bearing and 20mm shaft tolerance issue, leading to be a bit of play, that is a bit pants.
