Just after a bit of advice off the handy Andys of the stw world :D
I need to insulate our utility room, it’s a single skin/flat roof extension that connects the garage to the kitchen. There’s also a downstairs toilet attached so this will need insulating too, I’m going to add a rad/towel rail in there for some additional heating. Up to now I’ve ripped all the old flooring up and removed all the wall tiles (it was fully tiled for some reason).
Now what’s the best method of insulating, the room(s) aren’t huge so I don’t want to take up too much internal space. I was thinking baton out and 50mm celotex, does a vapour barrier go straight on the brick, then baton out with standard plasterboard on top (no need for the foil backed stuff?)? Any alternatives?
Cheers!
