.XLSX Gurus please....
[Closed] .XLSX Gurus please. Time identification formula
 benz
Guru's, help please.
I am trying to understand if a start and finish time includes a working period.
The context is that trucks arrive at a distribution centre on a specific date and time and leave on a specific date and time. This is evidenced on a log, which has arrival and departure columns in format dd/mm/yyyy hh:mm.
However, the trucks can only be worked between the hours of 0700hrs and 1600hrs.
Simply, what I am trying to do is understand whether the trucks arrived within that period.
Any thoughts?
Thanks!
Posted : 18/02/2020 11:12 am
Split the arrival time into a date & a time column and then:
=AND(A1>TIME(7,0,0),A1<TIME(16,0,0))
Posted : 18/02/2020 11:23 am
=IF(AND(HOUR(A1)>=7,HOUR(A1)<16),"YES","NO")
where A1 is the cell containing your datetime
Posted : 18/02/2020 11:25 am
better than mine..
Posted : 18/02/2020 11:28 am
 benz
Thanks both for your assistance.
Unfortunately, for some reason, the formula is not returning the expected result
Cell A1 contains:
02/01/2020 12:16:00
In custom format dd/mm/yyyy hh:mm
But, when I input the formula from ebygomm in cell B1, it is returning NO.
Any thoughts?
Posted : 18/02/2020 1:04 pm
The formula returns YES for me with that date
If you use =HOUR(A1) do you get 12?
Posted : 18/02/2020 1:26 pm
ebygomm's way worked for me although there are issues copying the text from the forum. I had to retype "Yes","no" for it to work. I guess there's some hidden formatting that Excel doesn't like.
EDIT: The code tags resolve that particular issue for me. Try copying / pasting from below.
=IF(AND(HOUR(A1)>=7,HOUR(A1)<16),"Yes","No")
Posted : 18/02/2020 1:46 pm
 benz
Yes, it is returning 12, but formula still returning NO.
As a workaround, I've created the start hour in another column using =HOUR(A1) and then =IF(AND(AJ3>=7, AJ3<=16), "Yes", "No").
Weird....
I'll drop you a PM....
Posted : 18/02/2020 1:52 pm
 benz
My fault....I incorrectly referenced the cell within the formula. The data was in cell I3 and I referenced I1...what a 'kin Muppet!
Thanks all for your patience and assistance.
IT WORKS 🙂
Posted : 18/02/2020 1:57 pm
Only thing to bear in mind as if the time is 16:00:00 exactly this will count as outside the time period, which may not be what you want.
Posted : 18/02/2020 2:08 pm
ebygomm’s way worked for me although there are issues copying the text from the forum. I had to retype “Yes”,”no” for it to work. I guess there’s some hidden formatting that Excel doesn’t like.
My money would be on the quote marks being some sort of Unicode chicanery rather than ASCII #34.
Posted : 18/02/2020 4:32 pm
