Wrapping up cement ...
[Closed] Wrapping up cement bonded asbestos.....
17 Users
So, my local council tip will take the cement bonded asbestos roof panels from my garage roof, if I "double bag" them.
Given that the panels are 3m x 1m, I can't find any rubble sacks big enough to bodge for the job - presumably a couple of big polythene sheets will do the trick, although I've not found anywhere local selling them - though I may not be looking in the right place
Posted : 01/11/2012 4:49 pm
In the trade, anthing too big to go in bags gets wrapped and duct taped. Have you considered a roll of cheap moisture barrier membrane for going under laminate floors?
Posted : 01/11/2012 4:55 pm
Ideally it should be a red inner bag/membrane and a clear outer one.
Posted : 01/11/2012 4:57 pm
I bought a load of clear poly sheet from ebay.
Posted : 01/11/2012 5:03 pm
As long as its marked as asbestos it dosent matter what color it is, iv done my awareness and safe removal courses, ensure some good tarp is used, wet with warm water and fairy liquid, fine mist as to stop any airborne, wear a white tyvex disposable suit and a decent face mask, gloves etc, then double wrap and ring local council, most councils do a free collect and dispose service, oh and double bag your dirty clothes also,
WTF? I just smashed up the sheets on our garage roof and wrapped them in the bags and the blue plastic sheet that we had to book out of the local dump. I wore a mask as a precaution; I'm still alive so it must have been OK.
It might be different if you were removing asbestos every day though.
Posted : 01/11/2012 6:25 pm
[i] I'm still alive so it must have been OK.[/i]
sometimes I think 'I really, really hope this is a troll post'.
Posted : 01/11/2012 6:27 pm
surely a leg pull-- if not a global idiot 😯
Posted : 01/11/2012 6:30 pm
chop it up with a disk cutter, then grind the pieces up in a pestle and mortar or a blendtec blender then cut it with SMA baby powder and sell it to drunk idiots outside nightclubs.
Posted : 01/11/2012 6:53 pm
Hope this is coincidence but I recall on the local news some fly tipping containing asbestos on No Mans Lane 😐
Posted : 01/11/2012 7:10 pm
If it is a real post its not the fact uve worn a mask, the fibres of asbestos are hook shaped and cling to clothing, if the clothing is still worn and you say brush past ur missues the spores become airborn again and inhaled, you wouldent realise til 5-10 years down the line, however if you have a good immune system you die faster as your body fights the asbestos and causes scarring on your lungs, if you have a shite immune system you last longer as your body ignores the asbestos. Dosent matter about prolonged periods, it takes one time thats all.
Posted : 01/11/2012 8:03 pm
Come back in 20 years and we'll see if you're still ok. My uncle died from mesothelioma 3 years ago, his exposure was in the 70's. If you smoke you're more at risk too.
Posted : 02/11/2012 7:32 am
[i]WTF? I just smashed up the sheets on our garage roof and wrapped them in the bags and the blue plastic sheet that we had to book out of the local dump. I wore a mask as a precaution; I'm still alive so it must have been OK.[/i]
Ignorance is bliss, eh?!
Posted : 02/11/2012 7:52 am
Stop giving him such a hard time, everyone knows that breathing in asbestos particles results in instant death, not the risk of a malignant cancer affecting many internal organs that would surface in 30-40 years time.
Posted : 02/11/2012 10:34 am
True but there are so many masks available in the market that helps to filter these particles outside the nose.
Posted : 02/11/2012 11:01 am
 Spud
A lot of waste companies will hire skips with locks for asbestos cement disposal. Or huge roll of 1000 gauge polythene, double wrap, gaffer tape up. Usually a red asbestos waste bag is taped to the outside. Please don't smash it up!!
Posted : 02/11/2012 11:40 am
If you have a toolstation near you then they sell plastic sheeting cheap. But don't go for really thin stuff as it will rip easily.
Use plenty of strong tape and maybe some strips of red insulation tape to highlight it's a hazard.
Be very careful!
Posted : 02/11/2012 11:51 am
Cement sheet is very low in asbestos content and the fibers are encapsulated in cement making the chance of release very low, this is why you don't need a license and you can use a paper mask and not a respirator. Spud description is the usual protocol for removal.
Posted : 02/11/2012 2:55 pm
*waves to coleman*
All our asbestos is still here on the premises - I saw that report as well
Thanks for the suggestions - seems our local council is happy for me to wrap the stuff and take it to the tip, but if I want them to remove it - even after I wrap it - it has to go through a private company and will cost me £500!
Posted : 03/11/2012 9:11 am
